when you push the o-ring in put a little screwdriver down the side of the oring to create an air gap that allows excess oil to bleed out. Otherwise you wont be able to jam the o-ring in properly.
And yes be carefull not to cross thread the big plastic end onto the shock body. |
Also use which brand name & Shore tire ?
Free practice coupon for registered TQ Racer !!!
Free practice coupon is now available.
Sign up www.tqrcracing.com. You will get Free practice coupon !! Click Here to sign up and print out the coupon to TQ RC RACING. This Saturday(3/20/2010), we will have regular practice day due to RCX 2010. We will have Wednesday racing as scheduled. Thanks. |
1 Attachment(s)
Hey, Has anyone tried out Orions Vortex Prostock 13.5 Brushless Part# ORI28215 in 1/12th 1c 3.7 lipo? how does this motor compare to the duo 1?
Side Mount Bullet Connectors
I am having trouble finding bullet connectors with the half-moon cut out on top for side mounting (90 degrees from wire to connector) battery connections. Any suggestions? I've looked everywhere! What is the proper name for these things?
1 Attachment(s)
Hey guys,
I am currently working on converting an old Cox .049 GTP Nissan to electric. I found it in a partially-assembled gas-powered state, so I decided to use hand-me-down parts from my other cars to complete it. It's going to be using the motor and ESC from my Evader ST and whatever receiver I can find. Seems to be going well so far. I've switched around the rear axle to put the diff/spur gear assembly on the side of the old motor mount. That way, I can modify the gas motor's mount slightly to make it accomodate the 540-size motor I'll be putting in. Everything is working so far, but if anyone has suggestions or pointers for me, I'd gladly accept them! The attached picture is the chassis with nothing on it, and before I flipped the axle and modified a few things... |
Originally Posted by kk4hg
(Post 7151949)
Originally Posted by TeamBear
(Post 7152666)
Hey kk4hg, just use the normal connectors and use a dremel or similar to grind a groove into the side and then just solder the wire on at a right angle to it,thats all I done and it works a treat,cheers.
Pinion Selection
Have a 12R5 almost completed. It has the Vector 8.5 turn motor and will be running 1S with the Novak Havoc. I currently have 19 and 20 tooth pinions. Should I consider more teeth? What are your thoughts? I will not be competing with this configuration, just practicing in a wide open, carpeted ballroom.
(Post 7151949)
(Post 7151949)
Any idea which lipo batter is suitable for Cyclone 12 thks.
Originally Posted by bl4
(Post 7157258)
8 MINUTE Races
Hey guys..
I am green as here, and need to prep up for a state titles in 4 weeks I have the car built.. RC12R5 Novak GTB 4Cell Novak Booster 1C 5000mAh 10.5T tekin Spur 98T 64P atm PINION: I have no idea where to start here, is it in the 25+T's like tourers, or 40 - 50T's? Any help appreciated. |
help
i am new to 1/12 scale and almost done building my 12r5.1 im just a bit confused on the booster module set up. i have a sxx competition ESC; what booster would you guys recommend? i was looking to buy the novak booster but then i saw the you guys are using TQ and Rc dybamics modules. that is basically all i need to finish my car and have it ready to go. thanks
| All times are GMT -7. It is currently 04:14 AM. |
