-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
Casper 05-21-2009 12:09 AM
Originally Posted by kn7671 (Post 5838640)
17.5 Rollout with 1-cell LiPo is around 100mm +/- 5.
I will keep that in my back pocket but I just learned tonight they will be running 1S with 13.5 against 17.5 round at our club. sooooo
Rollout for 1S 13.5 as well if you got it! Thanks!!!!
kn7671 05-21-2009 05:06 AM
Around 85mm +/- 5mm for 13.5 1-Cell LiPo.
theisgroup 05-21-2009 05:13 AM
anywhere from 85mm to 95mm. it all depends on motor and speedo.
TrevCoult 05-21-2009 06:17 AM
I've just put a short review of the CRC super soft sensor wire up on www.carsrcracing.co.uk.
Trev
Casper 05-21-2009 06:40 AM
Thanks guys!
EricF 05-21-2009 07:33 AM
Originally Posted by CarlosG. (Post 5839799)
All, I know is by August at the latest, we 12th scale racers down here In San Antonio will be up and running 13.5 and 1s LiPo for our stock class. Although by ROAR's definition it is not stock, but it will be close but not equivilant to 4 cell /17.5. We thought about 17.5/1s but for us here it would be to slow in the back straight-away.
Hey Yang, were are my tires????
Well why don't you just call it super stock as it's defined by ROAR:confused: why not call it what the class is, or do you think that may cause confussion to the masses?
I'm just asking... I'm not trying to insult you or get insulted, I think Chris and Yang have done that enough for the last couple of days:D
E
EricF 05-21-2009 07:38 AM
Originally Posted by chris moore (Post 5838682)
:Hey get off the porch and start running 1/12 again:lol::D
I'm working on it... I have a couple of lipo's on order, I still have some round cells but they may be a little iffy on the performance scale. I've been running 1/8 scale at HT. I think I'll be able to come up to SRS in a couple of weeks.
I've heard rummors that CH may pull the carpet and go to asphalt or myabe just start running the offroad wet to keeep the dust down. We'll see.
E
12thScaleCrazy 05-21-2009 07:56 AM
Trev
I thought CRC used this companies wire.
http://www.tqracing.com/sensor.htm
Casper 05-21-2009 07:57 AM
I just ran some numbers on those rollouts. Holly cow those are some big pinons. I was kind of expecting that but wow.
I am planning on running a CRC Gen X. What is the smallest spur you can get on one of these. Also anyone know what the total teeth you can put on the car is? (spur + pinion).
Thanks for the help guys!
theisgroup 05-21-2009 08:11 AM
prs has 71
EricF 05-21-2009 08:12 AM
I think the smallest spur is a 74 or 76 depending on which brand you buy also the dia. of diff rings drive this. The spur / pinion size combo will depend on your car; which I can't comment on as I don't have a gen X.
E
abailey21 05-21-2009 08:26 AM
RW goes down to 72 in 64p
kn7671 05-21-2009 08:34 AM
Yep, I was running a 54T Pinion on a 76T Spur with a 45mm tire at the beginning of the day. I have up to 60T Pinion's for smaller tires.
theisgroup 05-21-2009 08:44 AM
somewhere in these 2000+ pages, I think OD said about the smallest you could go would be a 71/72. any smaller and you would need run the smaller diff rings or i guess they call them the stealth diffs
abailey21 05-21-2009 08:46 AM
Yeah I haven't seen anyone making spurs smaller than like 71/72
