F.S CORALLY 12X U.S SPEC
Todd,
For starters, stop yelling. Turn the caps off. Secondly, there is a dedicated forum for selling things. This is not the appropriate place. |
Originally Posted by PW
1:28AM...Now I see why you called in today :nod:
I slept on the couch until ~3AM when my daughter woke up from coughing too much. After 2 nebulizer treatment she stopped coughing and got back to sleep at 4am. I got back in bed just in time for my wife alarm to go off at 4:30am. I was a fun night.... |
Hi Guys,
Can you tell me where I can find some good quality 16 gauges? The 14 gauges I am using is tweaking the rear pod. Thanks for the help. Ming |
Originally Posted by aoizip
Hi Guys,
Can you tell me where I can find some good quality 16 gauges? The 14 gauges I am using is tweaking the rear pod. Thanks for the help. Ming www.OD12.com |
Get your hands on some TQ dragwire...great stuff.
www.robotmarketplace.coma has black and red deans 16 high strand count cheap like 60cents a foot best place to buy it
thanks guys.. that place is cheap on wires!!
~Ming |
The current Yellow foam tire is a Jaco 2 Stage with White compound foam over the harder foam core.
why did JACO rename what is basicly a 2-stage white compound to 2-stage yellow? they didn't bother with Pink, Purple, Black, etc. |
Originally Posted by odpurple
I have 16 guage wire. It is high strand count and very flexible with a thin jacket, ideal for 1/12th. You can PM me or see my website for contact info :cool: www.OD12.com
Scottrik |
F brushes, .010 off the trailing edge, 2mm hole in face, red/green springs and around a 1.85-1.95 rollout depending on track. |
couple questions, that im sure have been answred, but didnt find them in a search...
what is the advantage/disadvantage of the flat vs angled servo mounts? talking about an L4 and a T-Fource, if that matters... and on the CRC-T i got, it is currently setup with damper tubes, and no side springs... is that correct? has mounts for side springs, but none fitted at the moment. and how does the CRC Graphite T-bar compare to the 'glass AE ones? |
what is the advantage/disadvantage of the flat vs angled servo mounts? talking about an L4 and a T-Fource, if that matters... and on the CRC-T i got, it is currently setup with damper tubes, and no side springs... is that correct? has mounts for side springs, but none fitted at the moment. and how does the CRC Graphite T-bar compare to the 'glass AE ones? the graphite t plate is to be used with side springs. an ae t plate is the side spring and setting tweak. i think. |
Originally Posted by AdrianM
Thats when my wife kicked me out of bed for coughing too much :rolleyes:
| All times are GMT -7. It is currently 01:02 AM. |
