-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
odpurple 06-12-2006 08:00 PM
Originally Posted by RAL
Questions
1. Curious..does silicone chock oil breakdown over time? I found some old bottles maybe 10 years old.
2. Do you still have to run caps on the motors...the 3 on the solder tabs?? On newer motors I think no. But I have an old reedy TI. Should I run them on that??
1. I don't think so, I have some AE shock oil thats a lot older than that and it still seems ok to me.
2. You still need capacitors on motors. Many motors come with them integrated into the endbell these days, though. If not you need to install them. Reedy TI motors require add-on caps.
RAL 06-12-2006 08:39 PM
Thanks!
AdrianM 06-12-2006 09:23 PM
All the Reedy Ti3 motors have caps on them now.
odpurple 06-12-2006 09:31 PM
Ok, thanks, good to know. The one I checked is a couple years old. He did say "old Reedy TI" though.
AdrianM 06-13-2006 01:11 PM
Riemon Axles and hubs are back in stock.
We are now carrying RW 64P gears in 88T and 92T. These sizes compliment the more common 96T, 98T and 100T gears that we have carried for years.
The 88 lets 19T racers run the gear they need for the torquey motors like the CP Money, Orion/Peak Element/Vantage, Reedy Quad 19 and Atlas motors without having to grind up your t-plates.
The 92 lets you split gear ratios and roll outs. If you run a 88 and a 96 you will find they generate the same gear ratios. A 92 lets you have access to ratios in between pinions changes on an 88 or 96.
I may be crazy but I have an axle built up and ready to go into the car with an 88 (in the car) and a 92 (in the pit box). If my tires wear and I cant get a roll out close enough that I fell good about it I can swap in the other axle and get exactly what I want no matter the tires size.
CarbonWorks 06-13-2006 01:26 PM
I want to try some ceramic diff balls. Does anyone know what the difference between the corally 1/8 balls and the IRS balls is, besides price? Is one better than the other? :confused:
RAL 06-13-2006 02:00 PM
For Komodo motors would it be bad to run an 88 since its more of an rpm motor. Just got an L4 and i'm not down with grinding the t-plate. But if using a 96 is really that much better...I'll get michaelangelo-esque with the dremel :D
Capelracer 06-13-2006 03:56 PM
Can I use the Hara conversion on an RC12L3, or do I need an L4???
odpurple 06-13-2006 04:37 PM
I've been using the ceramic balls from RC4less for a couple of years and they work very well for a really low price. They work as well and seem to last just as long as the IRS ones. I've never used the Corally ones.
AdrianM 06-13-2006 04:39 PM
The theory is the bigger spurs are better but out doors in 19T we just cant fit the gears we need sometimes (37 or 38/96) with little tires. I am running a Komodo now and I haven't bothered to put a 96 back on and I am not hurting for speed at all :sneaky:
odpurple 06-13-2006 04:40 PM
You can use either one. The only difference i can think of is that the Hara chassis is drilled for the larger L3 front body mounts.
Marcos.J 06-13-2006 05:39 PM
I have it on my 12L3
http://www.deadzoom.com/users/terri/DSCF2062.JPG
speedxl 06-13-2006 07:31 PM
Capel the car was designed to be a conversion for the 12l3. You can use a 12l4 if you'd like.
ickvanovs 06-14-2006 03:37 AM
what is Hara conversion?
MAD916 06-14-2006 05:00 AM
Race at Timezone this July 21,22,23 2006
2 Attachment(s)
Hey Guys: We just wanted to get a reminder about our Race this July 21, 22, 23, 2006 at Timezone Raceway Park in Washington State. Truly one of the finest permanent on road facilities in the United Sates, We will be running 10th scale and 12th scale Pan Cars as well as 10th scale touring cars. We attached an Ariel photo, an entry form and we guarantee you a great time.
for more information go to: www.timezoneracing.com
