Originally Posted by Anthony.L
Hey KayBee you are sounding a bit cocky lately. I'll be there Friday with the 1/12 to set ya back in place. ;)
-Korey |
HARA SETUP!!!!
Does anyone know where i can find a hara setup for a L3 (AH12 replaca)?
Just built up my CRC T-fource. IS there any reason not to use the included universal servo mount? I am using a hightec 81mg micro servo.
Originally Posted by RCCadet
Where can this item be found, I need it. I have not found thin CF.
Originally Posted by rchoudini
alway's just remember that you don't want any metel to metel contact.
female to batt. :nod: sorry about the typo's my daughter is falling asleep on my arm as we type Thanks Doug...at least SOMEBODY offered an answer to my question... :p |
If you're gonna run on carpet, make sure to get hold of Doug Powell and get you one of his "Sledge" chassis sets for the car... stiffer than the stock AH12 chassis for those real high bite situations. Powell Racing Components |
Originally Posted by Sushi Boy
Why bother? Dan or myself will put you both in your place BWAHAHAHAHA :sneaky:
-Korey |
I'll be down soon running 1/12. Mine should come into work tomorrow :D .
Ran 12th scale today for the first time at my local track and I cant beleive how much I liked it! I had never run one of these car's prior and I was surprised how easy they are to drive once you learn some throttle control/rythym. When you get it right it's an awesome feeling. i used suntan lotion for traction compound and it actually worked (the regulars had been using it) Thumbs up for 12th scale...
Originally Posted by Trips
Any local hobby shop that deals with Horizon can get one for you. Have them order HBS90200 and you'll be all set.
If you're gonna run on carpet, make sure to get hold of Doug Powell and get you one of his "Sledge" chassis sets for the car... stiffer than the stock AH12 chassis for those real high bite situations. Powell Racing Components i should have made this clear! im really looking for a setup sheet for my L3 but its a AH12 conversion!!! sorry hahaha. |
hey,
will 1/12 run okay in concrete? we dont have an asphalt track in our place. i heard thaT the tires (foam) is not suited for concrete. i hope you could help because im contemplating getting a kit..... |
We have been using a 1.9-2.1 rollout at our track. 2.1 is a bit stiff but the motor has plenty of torque to pull it.
Originally Posted by Mart42
Hi guys,
Want to try the new CO27 in 1/12, right now i use a ROar stock with a ratio of 1.50, what ratio you think is good with the co27. Thanks Martin |
CRC sells them on their website in there webstore. www.teamcrc.com |
go back a page or two and read CHicky's post. I too have tried servo up and servo down and I prefer it down on carpet as seen in my picture on the t-bar car. What I noiticed right away with servo up was more steering mid corner-a lot more. MOre than I'd want to go fast on carpet, but it would be good in low bite or asphalt to have the front end so locked in!!! Ray |
Originally Posted by odpurple
Connecters are for Sissies/Englishman/People who don't know how to solder. :D
Will that do? Just i would scarper for the exit sharpish though |
| All times are GMT -7. It is currently 11:00 PM. |
