Originally Posted by JayBee
Very true indeed :nod:
Them boys, Crashby and OD were fast today at Stockton.
Their Rev 4s hauled... |
what parts would be good to stock up for a 12L4? thx
Originally Posted by OVA
Hey
good job JB :cool: |
Shouldnt need much....T-bars and maybe a couple pair of IRS lowered Arms.
So those IRS lowered arms have a lower profile on the deck? So I can get more than 4mm of ride height if I wanted? I'm just looking for something that I can shim to play with like 3-5mm of ride height...
Yup, thats exactly they will do. They allow you to get a high ride height with smaller tires, or whatever size you have currently. What tires were you using at SIR? Sounds like everyone running some crazy combo like red in the fornt and pink in the rear.
-Korey |
-Korey |
Bill - you forgot the 1st and 2nd place cars of Chris & Myself both of which are Rev 4's. I got a horrible start in the main and was never able to make it back up. Chris had a good car in the main as well. You need to get yours done. See you Wed.
12th scale setup boards
Hi all
I am looking to buy a setup board for 12th scale racing. I have seen both Hudy and Integy which use an adhesive label. I also am aware that Tamiya makes an aluminum version for 10th scale and Trinity makes an aluminum version. What do you all reccomend for pancar? Specifically for measuring track width and adjustment of left vs right axle lengths. Also, is the Niftech setup gauge p/n 3001-187 worth it? Thanks |
Originally Posted by JRX-S Bill
Is your car totally stock?
guys.. may I know why 1/12th scale are prode to spinning? I mean when coming out of corner.
Could this be due to diff is too tight? or any other tips?? |
Could be your diff is too tight. But if you have a t-plate car, you may not have enough droop in your car (rear pod hangs a little lower than your chassis). It also could be tweak or the distance from center of your car to the outside of each wheel could be off too.
There are a number of things that can be the cause of this type of problem. Hope you find out what it is. |
my car does have the T plate. its a Kawada M300SP. I am confused with the droop in 12th scale... can you explain it a bit?
thanks |
| All times are GMT -7. It is currently 08:09 PM. |
