-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
fast-ho-cars 10-21-2005 08:37 PM
scottirk
wasn't disagreeing with your statement on incentives to cheat on batteries.
on batteries, i was just stating....more or less that the factory ratings on the wrapper may not truly always truly reflect actual milliamp rating.
example:
recently another cell in now in the fray IP3800 (Infinite Power). they look like they have some high voltage outputs.Danny/SMC has stated these are actually a 3600 in another RCtech forum.
my original issue was with the sudden ban on 2-stage/wrap tires. supposedly they can reduce laptimes up to 3+- tenths or hundreds of a second. wow that's way less than 5% and it's sudden frontline issue. Cost...to me not a issue. i only pay $3-4 more for them.
tomdav 10-21-2005 09:02 PM
2 stage
For the extra cash do you get more useful life out of a two stage tire?
I just started racing 1/12 last year and I'm hooked. These cars are fast and for the most part way cheaper then the 1/10 sedan(nothing against sedan) And while everyone talks about making heats longer because of the new batteries I'm on the driver stand hearing 3 minutes down five to go :lol: Now if I could only convince everyone they should ditch their sedans and join the fun.
dakrat 10-21-2005 10:32 PM
"once you go 1/12, you never go back"
Pro ten Holland 10-21-2005 11:32 PM
Originally Posted by Pro ten Holland
I'm looking for a good standup brush for my 10turn motor. Are these any good:
http://www2.towerhobbies.com/cgi-bin...?&I=LXFBH4&P=7 ?
What spring combo should work best?
And at what lenght should I toss 'em?
anyone?
New questions:
1. With the third screw on the T-bar removed. Is there any danger of the rear pod going out of alignment with main chassis? I noticed this on my 10th pancar last week. It didn't really hurt its handling, but I think it will be more noticeable on a 12th scaler.
2. What will removing the T-bar brace do to the car's handling? How does it compare to using a softer T-bar, or removing the third screw on the T-bar?
anyone?
fast-ho-cars 10-21-2005 11:45 PM
anyone?
yep they are good ones to run but sometimes hard to find at our local shops, so i also use orion sprint brushes for a 10x1 or 11x2 orion core touring motor (pre-V2)
springs. i use a mix of trinity silver, blue, or green springs
T-bar, the middle third screw is usually removed to increase rear traction, alignment shouldn't be a issue. however your t-bar is more prone to break from a hard hit/crash
brace across the t-bar mounted above the pivots? i don't run one doesn't seem to hinder/help. was told it was there to reduce chassis flex and prevent the shifting/tweak of the t-bar/pivot mount screws.
radio_car_racer 10-22-2005 05:20 AM
UK National Series Videos
click on the links for some short video clips from our recent 12th National @ Crewe here in the UK. Then either save or play.
A final
C final
E final
bikedoctor 10-22-2005 08:02 AM
Thank you for the video.
Where can we see photos of the cars?
OVA 10-22-2005 08:59 AM
Hmm I would n't know about that....I like sedan over 12th scale .but again 12th scale is a fun car...
Katana Man 10-22-2005 12:18 PM
The white 12L4 says to the blue 12L4, "Which way to the closest race track?"
http://www.comparecenter.com/photoda.../IMG_6667m.jpg
bikedoctor 10-22-2005 12:47 PM
I love the Mobil 1 paint job.
Where did you get the sticker set?
Are the stickers external or internal?
Formula1fan 10-22-2005 12:50 PM
I second that, who painted that?
ziggy12345 10-22-2005 02:21 PM
Has anybody tried a brushlkess motor with LiPo cells in a 1/12? I want to try it. I also have a spektrum system. What issues have i got to deal with?
I know i will need something to reduce the voltage to the servos as the spektrum doesnt reduce it. What else?
Cheers
odpurple 10-22-2005 03:19 PM
Cheers
no reciever reduces the servo voltage. that is done be the esc.
ziggy12345 10-22-2005 03:24 PM
Not on the spektrum it doesnt. It hasnt got a BEC installed
Cheers
