Ream
I was wondering what size drill bit to use for the steering blocks? I have the newer ass. front end. They are very very tight out of the box. Anyone know the size bit to use for the Castor blocks? They are super tight as well.
Thanks. |
Well Im back! I got tied up with work the last couple of days. What do you guys think of the new Black Widow? Is the T-Fource Team Red car a T-bar car and what do you all think about this car, any weak points?
Thanks for all the help! Scott |
Thanks. Castor blocks: 2mm, but they are supposed to be tight. |
Thanks for all the help! Scott yep the "T"-Fource has a "T"-bar |
I would like to modify my 12L4, I'd like to use damper tubes in it, I think damper tubes should work better than the damper disk because isolates the side to side damping from the for and aft damping.... any idea how to make this mod?, I know the best would be to buy a whole new chassis, or a conversion like the BMI or the CRC T-Fource....., but if I can modify my L4 without changing the whole chassis, I'd rather do that. Any ideas.....
If you do not have lowered pod plates, then you could order the IRS four screw kit for the IRS Rug Rat conversion, part number IRS1162, which gives you lowered pod plates and a four screw top plate with holes for dampener tubes. Cost is $47.95. You would still need to order the dampener tubes from CRC. |
thx
Originally Posted by odpurple
Steering blocks: .125" (1/8)
http://www.teamcrc.com/crc/modules.p...od&prodID=1328 gets you the tubes, graphite, and hardware to put tubes on the l4 without changing chassis' or pod plates |
gets you the tubes, graphite, and hardware to put tubes on the l4 without changing chassis' or pod plates johnnywhopper would you please tell me what is exactly included in the uni-tune kit 1328 from CRC?, is it a direct fit to the L4? Has any of you converted your L4 to tubes? what do you think about the idea? Thanks J |
Hey Jorge,
The best way is to sold your L4 and get a nice bloody T-Fource :nod: You should take a look to the Hyperform 12, this is a convertion for the L4. I have one, maybe we can work something, i am very happy by the performance of my CRC T-Fource, i think i will stay with it. e-mail me if you want some infos. Thanks |
trim
doh.
Originally Posted by Mart42
Hey Jorge,
The best way is to sold your L4 and get a nice bloody T-Fource :nod: You should take a look to the Hyperform 12, this is a convertion for the L4. I have one, maybe we can work something, i am very happy by the performance of my CRC T-Fource, i think i will stay with it. e-mail me if you want some infos. Thanks Yeah I am thinking about the T-Fource, I think it will be my next buy..... I saw your T-Fource run and it really looks fast see you next race |
Getting into the 1/12th game. What's a good quick servo?
Can't go wrong with the Futaba 9650.
Aitronics 94145, Ko Propo 949, Jr 3550 and the new 3650 are good choices. |
Okie i'm going to order a CRC Carpet Knife 3.2R and keep my L4 for outdoor only.
I'm going to order it from CRC website so want to know what spare/hop-up part should i order at the same time as there is no local shop selling CRC car/parts and i want to be prepared in case i break somehthing What should i get? Any parts of the car break easily/most often? Any parts i should upgrade? Any feedback/commetns greatly appreciated |
| All times are GMT -7. It is currently 06:02 AM. |
