XXX-S Tips and Talk for Stock Classes
#241
Never used the solid diff with the stock axles. I had the IRS ones with the pin cushions and it never caused a problem. You may be using to much steering. The X has a lot of steering and a pretty fair amount of Ackerman. Also, are you using the stock front hinge pin block ?? If so, try using a rear block in the front. It will straighten the axle angle and may help.
http://www.rctech.net/forum/922179-post10967.html
Matt ran that same sort of setup just about everywhere he ran outdoor. My car gets better every time I run it and get it more dialed in.
I made myself a set of BK Bones and it really, really helped the diff. I showed it to a buddy of mine who asked "Did you rebuild the diff?" to which I responded "I cleaned it, but no." He was amazed. It's like having a brand new outdrive every run.
If you look at Cav's setup from the same race (when he won), he had a 2R in the front, the axles straightend out, a spool, and a lot softer springs (green and blue, I think). Other than the CVD bone issue, it narrows the track a lot. The Losi guys were running .255 hexes (stock TC3 size) in the front to get the track width back. And I'm already doing that to square the front with the +6 rear.
I'm not sure how I'd make it any wider...
#242
I've been running this setup (Matt Francis Reedy Race 2004), with a couple of changes (low rear roll center, ride height for VTA tires):
#243
Ran the GT / silvercan class locally yesterday: 12-13 cars total for the day, qualified 1-2-1, putting me right up front in the main. Got hacked real bad in the beginning but still finished 2nd, only being beat out by a new-ish Xray. I had the fastest lap of the main, so the speed was there just had a rough bout with traffic (one problem with this class locally is it does draw out some "all throttle no control" types). I don't think anyone had a better car through the infield. Not bad for a car I paid $80 bux for a year ago .
#244
Brushless pinion spur?
What 64 pitch spur and pinion have people been running
for 13.5, 17.5 and/or 21.5. (Assuming large flowing asphalt track)
I read the Novak web site recommendations and it seemed like to meet their gearing recommendations it required a very large pinion on the smallest available spur.
I wondered what real world experience people had.
#245
#247
from Novak site
Novak web page
Recommended for 13.5 4.5 - would require 108/44
Recommended for 17.5 3.5 - would require 90/47
Does this match your experience?
#248
Do you have the alloy spur gear adapter ?? Those ratios aren't bad but remember they are "suggested starting ratios" only.
And remember that there are only a couple of 64p Losi spurs available. Without the adapter you may have to settle for 48p. That makes things a bit more difficult.
#249
looking for xxxs
anybody selling a xxxs or xxxs g+ pm me your price ty
#252
Btw, just checking into the group!! I just picked up a mint G+ with a boat load of parts. Looks hardly used, probably in stock/expert stock.
I'll be running in intermediate stock (or try sportsman stock if i can keep up)
Plan B is to run in a VTA class at the same track.
I'll keep you guys posted!!
Soup
Soup
#253
pictures please
@soupinmycoupe: how much did you paid for it iam also looking for one, please post pictures, thank you
