Schumacher Corner
When PW was telling me the stuff that some of the other guys were doing I was sitting there like " there is NO WAY that will work" He agreed that it was completely backwards from what were doing....totally wierd LOL
Originally Posted by RKeasler
Adrian was it mostly because his braking and acceleration points were different or what?
Rod
Rod
Originally Posted by AdrianM
He drives tighter....everywhere. He lets off sooner and brakes earlier than I do and this reduction in speed makes him not blow wide in the corners...like I do.
Originally Posted by mini-dub
I hear he also goes straight down the back straight .
Originally Posted by aus jd 2703
hey whats a good shock length so that i can get droop and ride hight at about 9mm combine?? (4mm droop 5mm ride hight?)
also can u run the same all round??
thanks in advance
thanks in advance
I am using the low shock towers and TRF shocks. And although I have not tried it, I can run the same droop setting all the way round.
HTH
Darren
Originally Posted by Matt Howard
still looking for that first win at SWR?
Originally Posted by STLNLST
Made Goss go home cause I held the TQ from round 2 on. Made a slight change for the main and paid the price. It's all testing for the nats. Speedworld is built on top of old slavery grounds or something because I can't catch a break there
yeah but I received a PM from an "anonymous source" you said this was for the STOCK class Man up and run some mod you cherrypicker
I finally converted to brushless on the weekend!
Nosram 4 star, better than I had expected, but took a few runs to get used to but once dialled in I felt it was equal to a decent 7. but without having to true and change brushes every run it was heavenly!
No going back for me now, more time to wrench on the car and talk shit in the pits.
R/C Tech Elite Member
Hi Guys
Currently running a EC (rubber version) with very standard settings, on tarmac using rubbers and very happy wit it and teh setup we have.
This weekend we are racing somewhere different again tarmac but we may have to use foams. What changes would I have to make for foams. Presume less camber and maybe one stiffer spring - anything else?
Did your "Anonymous Source" tell you that he has shaved his head? I think he lost a bet to somebody......was it you?
Hi Heavy, I would recommend removing the suspension riser plates both front and rear, with the front arm blocks either flat on the chassis or raised just 1mm or so, with the rear arms blocks equal in height or 1mm higher.
Springs is dependant on grip level of track and surface (bumps etc) but 1-2 rates harder than kit would be a good starting point. and possibly the removal of sway bars.
These have been some general findings of mine running foams on the previous Mi2, I havent as yet run foams on the E.C.
perhaps some of the U.S team who have more experience with the foam car can comment, on their general setup changes from rubber to foam.
Originally Posted by Advil
Hey Matt,
