Schumacher Corner
Tech Legend
Trader Rating: 51 (100%+)
mini-dub you ever messed with raising the rear ball stud on the hub? Any opinions on what that has done for your car?
Brian
Brian
Wyd - It should make your car rotate more. Note that you can add up to 1mm but you WILL have to remove material from the top of the ball cup so it dosent contact the rim.
Tech Legend
Tech Legend
Hey Bob I'm staying ahead of you............I will be ordering a few more goodies tommorrow from Schumacher.
PW took me to school when he test drove my car Saturday. I know he's fast but man...he was up to 1 sec a lap faster than me with my own car!
Adrian did you run the rear tower mod or just a stock one? Also what did you run for roll center shims. I am just running the riser plates now.
Thats awesome LOL. Dont you just love it when you are like...Ok my car is as good as its going to get...I got this time out of it. Then you give it to someone else and they blaze past your time LOL
gotta love it.
Location: A step closer to where I need to be a step further from where I was
After watching him for a few laps I got the times down so he was ONLY half a sec per lap faster than me....
Rod
Brian
Brian
yeah my theory of a Schumacher car on foam tires is that it's just frikkan wierd man....LOL I compare it to a Losi buggy. You have to do stuff to the car that you know just isnt going to work.....but it does.
Tech Legend
Originally Posted by mini-dub
Yeah, here's what I've found on the Mi2(EC). The raised outer stud gives a similar feel to me of a short link. The car transitions really well, and has good initial traction but can break free harder and will be less controllable. It also rotates harder link Adrian said, but where I find this is most noticable is exiting the corner. You should have much more onthrottle steering, but then the opposite goes for off throttle until you make a hard move and it breaks free. Make sense? People should remember that my setup knowledge is mainly for setting up a rubber tire car. Some of the stuff is consistant when you switch to foam tires but many things between setting up a foam and rubber car seem to be opposite as we found at the Novak .
