Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 01-14-2006, 04:32 AM
  #12811
hers sum pics of my mi2ec all finished ready to race 2moro.
Attached Thumbnails Schumacher Corner-mi2ec.jpg   Schumacher Corner-mi2ec1.jpg   Schumacher Corner-mi2ec2.jpg
bob33 is offline
Old 01-14-2006, 08:10 AM
  #12812
IslandBwoy's Avatar
nice body.
IslandBwoy is offline
Old 01-14-2006, 01:53 PM
  #12813
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Here is mine
Marcos.J is offline
Old 01-14-2006, 02:12 PM
  #12814
IslandBwoy's Avatar
Default Setup Drill
So you run the alloy hinge bocks all around in the rear and use the alloy hub carrier with a 0 degree spacer giving you exactly 2 degrees of toe in with 1 mil spacers under the hinge blocks as recommended.
Track conditions: temperature (cool), medium bite
Time to test: when coming around the sweeper the car gets loose putting you side ways. What should you do?
a. remove the 1 mil spacers from under the rear pivot blocks
b. insert a 1 degree spacer in the hub carrier increasing toe from 2 to 3
c. remove the 1 mil space from the two rear pivot blocks. End result 1 mil of anti dive
I'll post what the end result of each was after i get some feekback.
Thanks,
R
Refer to setup posted here: Weylin's Setup
Old 01-14-2006, 03:19 PM
  #12815
mutley001's Avatar
Very simple paint job Marcos. J, but i like it!!!!
IslandBwoy
I've used all of those to achieve the desired effect, it just comes down to personal preference! prrsonally I prefer a) and think b) is the least favorable due to the rolling resistance but all will work.
Paul
mutley001 is offline
Old 01-14-2006, 04:39 PM
  #12816
mo
mo's Avatar
My EC is all ready to run.
Too bad I there is no racing for 2 more weeks.
mo is offline
Old 01-14-2006, 06:28 PM
  #12817
AdrianM's Avatar
Originally Posted by Racer X
STLNLST must have gotten his car, it's been SO quiet for most of the last 24hrs...
...how about a 'thank you' to Adrain?
AdrianM is offline
Old 01-14-2006, 06:30 PM
  #12818
ChadCapece's Avatar
Originally Posted by RKeasler
STEELER NATION NAYSAYERS BEWARE!!!!
Rod
RK, I think you forgot who they are playing
Colts > Steelers
ChadCapece is offline
Old 01-14-2006, 07:25 PM
  #12819
HarshGuy's Avatar
You could go to Gilroy ...tomorrow even!
HarshGuy is offline
Old 01-14-2006, 09:46 PM
  #12820
I am!!!! I cant take it any longer!!!
bigdog is offline
Old 01-14-2006, 10:25 PM
  #12821
Hey guys I have a keyence speedo the 2002 and I dont know how to work it. I just put it in my car and its like the brakes are on at all times. I meaan the motors are SLOW!!!!! and as soon as i lift off the throttle the car just complety stops(no rolling)full brakes... I didnt really mess with it, just opened it from new and put it in and ran the stock setting and this is what happens, Can anyone help me out on this, I looked at the manual and it is very complicated, cant understand what to do, Can someone tell and or show me step by step how to do this. Any info/ help would be very appreciated.
James
James605 is offline
Old 01-14-2006, 10:36 PM
  #12822
Call Adrian @ Schumacher, he is the Keyence master. He willl hook you up no problem!
Jay Dub is offline
Old 01-14-2006, 10:45 PM
  #12823
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
Default Set up
Islandbwoy,
Change your set up from weylins to Paul's set up. It is a very stable set up.
It works great @ Superior and Speedline.
http://www.racing-cars.com/usa/image...ew_asphalt.pdf
Regards,
Eric
RED-LINE M03 is offline
  #12824
Can i get ahold of him in here? Do you have the number handy by chance, if not no problem i can look it up.
James605 is offline
Old 01-14-2006, 10:48 PM
  #12825
Default E-mail
E-mail [email protected] or just send him a P.M.
Adrian is top notch.............
