Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 11-05-2005, 04:33 PM
  #11641
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
Originally Posted by Jon Kerr
Or add a fan. Functional weight is a god thing.
Not only is it a God thing it's a good thing as well.
RKeasler is offline
Old 11-05-2005, 04:37 PM
  #11642
RKeasler's Avatar
Originally Posted by IslandBwoy
Well other than keeping the motor cooler. what does the fan provide? Can i as a result of adding the fan run higher ratios? 'cause personally i've never had a problem overheating a motor in 19T. But then again maybe thats why i'm slow :-(
BTW: I've noticed that some of the setup sheets call for blue front and silver rear springs. And then others would call for the opposite. ???
What setup did you see that had harder springs in the back? I haven't seen that yet. I have seen the one with thicker oil in the rear.
Rod
RKeasler is offline
Old 11-05-2005, 09:03 PM
  #11643
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Oops!
Keeping the motor cool, especially in 19 turn and stock is very important. We gear these motors up from 6.2 all the way up to 5.7 at times. That's a lot of gear and can get the motor very hot if you don't have some sort of cooling. You look at most factory drivers cars and they'll more than likely have some kind of fan on the motor, ESC, or both.
Jon Kerr is offline
Old 11-06-2005, 02:56 AM
  #11644
Taffyjnr5's Avatar
Trader Rating: 32 (100%+)
Hi Guys,
I am thinking of using my spare car in 540 stock class (silvercan johnson /mabuchi) and was wondering if anyone knows what overall ratio gearing i should start with.
Taffyjnr5
Taffyjnr5 is offline
Old 11-06-2005, 10:45 PM
  #11645
nf_ekt's Avatar
Trader Rating: 115 (100%+)
Oops!
Are there any companys out there producing a (dual) fan setup for the mi2, or is it a diy project only?
nf_ekt is offline
Old 11-06-2005, 10:52 PM
  #11646
RKeasler's Avatar
www.coolcanfan.com
RKeasler is offline
Old 11-07-2005, 07:03 AM
  #11647
Taffyjnr5's Avatar
I am trying to find a part number for the main belt on Teemus car or the new EC I have down loaded a heap of photos but cant quite make out the part number I think it is a gates belt as the part number is similar to the standard one.
Taffyjnr5
Old 11-07-2005, 07:23 AM
  #11648
Jon Kerr's Avatar
Originally Posted by Taffyjnr5
Hi Guys,
Taffyjnr5
I have no idea how to gear those motors. I'd start a little higher than what you'd normally gear a stock motor at and go from there. Sorry I couldn't be more help.
Jon Kerr is offline
Old 11-07-2005, 07:31 AM
  #11649
howard hudson's Avatar
Hi Guys,
Taffyjnr5
as far as I know just put the biggest pinion you have on it and never lift There is a group of locals here in california ( a very small group) that gets all wet in the pants when you say the word mabuchi. One thing that strikes me funny about them is that they buy the slowest motor out there then they try to make it faster If you go to the racing forum and click on the T A O B thread I think you can get some answers there.
howard hudson is offline
Old 11-07-2005, 12:16 PM
  #11650
Oasis's Avatar
Trader Rating: 38 (100%+)
Originally Posted by howard hudson
One thing that strikes me funny about them is that they buy the slowest motor out there then they try to make it faster .
Oasis is offline
Old 11-07-2005, 01:16 PM
  #11651
Taffyjnr5
as i no, that belt is not out to buy yet, but i could be wrong
bob33 is offline
Old 11-07-2005, 04:29 PM
  #11652
Taffyjnr5's Avatar
Talking
as it is a gates belt I should be able to get it from them I just need a part number off the belt itself and i can get it from gates belts.I can see the part number from the photos of Teemus car but can not read them properly.
Taffyjnr5
Old 11-07-2005, 04:47 PM
  #11653
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
you need a 513-3MR-3 you can get it (custom made)from gates belt ,or the Belt corporation ,I have to find the phone # they have them in stock but you have to buy like 10 belts because they have a minimum for shipping.
Marcos.J is offline
Old 11-07-2005, 05:17 PM
  #11654
seaball's Avatar
Default 171t x 3mm belt
http://www.rcmodels.com/rc-cen-ct021.html
seaball is offline
Old 11-07-2005, 05:22 PM
  #11655
Super Moderator
Marcos.J's Avatar
Originally Posted by seaball
thats pretty good but i paid $2.65 per belt!
Marcos.J is offline
