Schumacher Corner
Originally Posted by PW
I would suspect production models will be running at the Birds
Anyone attending the I-Hobby show this weekend in L.A. please stop by and check out the booth My personal car has been taken away for everyone to check out....please be nice to her
Originally Posted by STLNLST
PW when do you leave for the show? I have a couple of questions about the set up you posted.
Are you ever going to get to stay home from more than a week at a time?
Jon,
I went out for another run using the PW setup and it was still quite taily even when the tyres come up to temp anything you can suggest maybe raising the rear roll centre 1mm from standard.
Taffyjnr5
Taffyjnr5
I switched the blue springs on front and silver on back had. Took the antidive out of the front and went to 27s and mishark is dialed. Still no ft. riaser plate. will try that later Im staying with what works.
thanks Jon taking out the washers up front and going to a lighter oil helps the car alot!
Coned Spacer
Hey Guys,
I'm not sure how but i seemed to have misplaced my spacer (long) for my spur gear assembly and was wondering if anyone knew of a temporary way to replace that part until i get a new one.
Any suggestions would be appreciated.
R.
R.
Originally Posted by Taffyjnr5
Jon,
Taffyjnr5
Taffyjnr5
Jon,
Exit under power.
Taffyjnr5
Exit under power.
Taffyjnr5
Add some front droop. This will help the car transfer more weight to the rear on power. Also, watch the attitude of the car and have someone else watch the car. If it looks like it's rolling over too much or not rolling over at all, there could be other things that need to be addressed.
OK I will try that then I was maybe thinking that some rear antiquat 1mm might help but hey your the pro.
Taffyjnr5
Taffyjnr5
Far from a pro! But I try to help. I've been trying to get away from using antisquat. Only if it's really needed. Try the droop first then if that doesn't work, do the anti squat. What droop are you running in the front now?
Jon,
I am running 3mm front droop and 4mm rear.
Taffyjnr5
Taffyjnr5
Go to 3.5 in the front and try it. Then try .5mm antisquat. 1mm max. I'm actually running 3.5mm droop in the front and 4.5 in the back right now.
Hey Jon is it better to use the stock raiser plate in the front when using the BMI chassis?
Taffyjnr5
Taffyjnr5
I'm not sure why these things have made the car so much better, maybe John has an idea?
