Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 07-26-2005, 06:13 AM
  #10411
TimPotter's Avatar
Trader Rating: 15 (100%+)
Has anyone used the Cool Can mount for fans ? And what are your opinions on best location for optimum cooling ?
TimPotter is offline
Old 07-26-2005, 07:33 AM
  #10412
AdrianM's Avatar
Originally Posted by Iain
I thought the raised transmission was purely to make the transmission more efficient, by allowing the dogbones to sit level instead of being angled down or is that the Teemu Towers?
Are the Teemu tower's (U2787) that have to be used with the Teemu Riser's the same as the low towers (U2714 and U2715) or are they slightly different (Say for low grip?)?? What about the BMI towers? Are they the same as the low towers, but with the body post mounts on them??
Also, with the 3700 Teemu Chassis, is there any problem using 3300's in it, they don't sit too low or anything?? As I still have a few 3300's left to use but imagine in not too long will have all 3700's?
Iain
The raised drive train increases dogbone plunge into the drive cup and raises the CG for more weight transfer. The increased plunge should reduce on power traction but its effects are minimal. The higher CG make the car roll more for more weight transfer/traction.
The Teemu towers have all the holes moved down 2mm to compensate for the diff riser plates.
The 3300's fit in 3700 slots just fine if your cells are not glued together. If they are they will ride a bit higher than the 3700's.
AdrianM is offline
Old 07-26-2005, 08:35 AM
  #10413
What shells are people using now on a Mission on carpet, tight, on rubber tyres please, so I know what to order.
Thanks in advance, also, is there a good base setting for the mission on carpet/rubber tyres???
DA_cookie_monst is offline
Old 07-26-2005, 08:44 AM
  #10414
John_S's Avatar
i always liked alpha 2.0 on tight tracks
John_S is offline
Old 07-26-2005, 08:49 AM
  #10415
belgianchamp's Avatar
There are 2 populair body's : dodge stratus 3.0 and the mazda 6.0 for racing indoor on small tracks i see that the Alfa 156 is still used allot.I use the Dodge stratus 1.0 for carpet and the mazda 6.0 for outdoor on asphalt.Thats also the choice of the driver himself.( his drivingstyle)
for setups look @ this link : http://www.racing-cars.com/search.as...e1=prodvalue14
belgianchamp is offline
Old 07-26-2005, 09:05 AM
  #10416
AdrianM's Avatar
For Carpet Rubber tires the Protoform Maxda 6 or Stratus 3.0 All Purpose are the the best.
For Carpet Foam tires the Parma Alfa is the only choice.
AdrianM is offline
Old 07-26-2005, 10:32 AM
  #10417
Thanks for the Shell advice, I was wondering whether to go for the Mazda 6 or the Strauts 3.0.
As for setups, I been to Schumachers site (my first port of call) and they vary so much, especialy the shock oil.
Old 07-26-2005, 10:55 AM
  #10418
Iain's Avatar
Thanks Adrian.
Iain is offline
Old 07-26-2005, 11:10 AM
  #10419
Jack Smash's Avatar
Trader Rating: 35 (100%+)
Go to www.gearchart.com for setups. Jason Moberly has quite a few Rubber Tire Carpet setups on there that work great.
Jack Smash is offline
Old 07-26-2005, 11:11 AM
  #10420
Trader Rating: 18 (100%+)
Hey Jack have you tried the car out yet or still having gliching problems?
Roberto Falcon is offline
Old 07-26-2005, 02:28 PM
  #10421
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I just got my new set of Schumacher tools. I can't wait to use them. I've got a bunch of wrenching to do tonight to get the car ready for the Hitec race this weekend.
Jon Kerr is offline
Old 07-26-2005, 02:43 PM
  #10422
PW
PW's Avatar
Those tools are sweet
PW is offline
Old 07-26-2005, 02:46 PM
  #10423
Jon Kerr's Avatar
I can't believe these things retail for only $8 each.
Jon Kerr is offline
Old 07-26-2005, 02:48 PM
  #10424
Jack Smash's Avatar
I ran a loner MI2 with spektrum this weekend with my transmitter. Qualified 5th in 19turn and had the 3rd fastest single lap at a track I have never run at but had to pull off on the first lap of the main, still glitching.
I guess I'll just start throwing money at it till I get it straightened out.
Old 07-26-2005, 02:56 PM
  #10425
PW
PW's Avatar
27mhz has always straighten out glitching on my side
Sadly the price went up slightly $10.99, but still an awesome price for what you get!!!!!!!
PW is offline
