Schumacher Corner
Originally Posted by Arjen
Next sunday is the 4th round of the dutch nationals.
last sunday there was een kind of an pre race.
The car was pretty good and qualified 2nd.
but i found out that my car falls still in the corners.
So i need a little more corner speed and roll.
the setup further was good but with more corner speed and roll i could be a little bit faster.
my setup now:
Front:
50 oil 3 holes
asso blue 17.0 lbs
2nd outer hole on shock tower
outer hole on the lower arm
middle top camberlink
1.5 camber
0.5 toe out
one way
alloy pivot blocks
Back:
40 oil 3 holes
asso silver 14.5 lbs
3rd outer hole on shocktower
2nd outer hole on the lower arm
1.5 camber
3 toe in inboard
alloy pivot blocks
battery front inside
19turn element orion stock motor (hand out)
I thougt i could maby try roll bars but maybe that would change the grip to much.
Do you guys have a couple of tips for me what i can try?
Arjen
my setup now:
Front:
50 oil 3 holes
asso blue 17.0 lbs
1.5 camber
0.5 toe out
one way
alloy pivot blocks
Back:
40 oil 3 holes
1.5 camber
3 toe in inboard
alloy pivot blocks
Arjen
Jon, I noticed in the Spool Benefits thread you mentioned that a one-way isn't relly suited to the Mi2.
Could you explain why? I've just put the Tamiya shocks on my car and my next item to get was going to be a one-way (if I continue to need more turn-in) - so I'm interested to hear about your experiences.
I've noticed that out of all the Mi2 setups on the net - only Teemu consistantly uses a one-way, in fact I don't think I've seen a setup of his without one
bender...I don't think it matters what car really, just the type of track. Most European tracks are oneway friendly and most USA tracks are not. Most of the euro tracks are very large and flowing and the USA tracks are smaller maze type tracks where you point a shoot. Wish we had some more tracks like the euro tracks
Almost all european racers that come to the US try the oneway, but always end up running the spool
Here are some pics of my new paint job. The car sure does hunker down ripping out of a corner with a 7x1 !
PW hit the nail on the head. However, when I ran a Losi car, I liked the one way on almost every track I went to. It was easier to drive and handled better. The exact opposite has been true with the MI2. I know many of the other team guys also like the spool only. In the spool thread I should have made it more clear that it was my experiance that the MI2 didn't like the one way. Sorry for the confusion.
Adrian- Looking good. You do the paint?
Adrian, you still race ?
What is the saying... Blind Squirrel....
Well come on down here and run at our track :> I added a picture of my car too
Didn't I bump you out of the 19T A-main at the last Tampa State Race....
I wish you could take a pic that would convey the horror of a 1/12th car hit hitting a cement block and decelerating from 35mph to 0 on 0"...lol!
Paint job looks cool!!
HELP
PW/Jon Kerr/AdrianM:
what is the effect of the length of the Centre Track Rod on the steering assembly? definitely if i add length to it, my camber links would be shorter and vice versa... any track tips on this? what length do you guys use? hope you can help me out
Carlo
Carlo
Originally Posted by PW
Yes he does.... What a jerk for ignoring you
Carlo
Carlo
