Schumacher Corner
Ginsu ,
What can we expect on the new version of the mission? Lower CG? Battery tray similar to the new Yokomo system? Any info would be helpful. I am holding out for the new Schumacher and would appreciate any info at all as to what changes or improvements will be added to the new car. Also any word on when we can expect to see the new 4wheel drive off roader here in the states? Thanks
LOOK @ THIS:
http://www.rczone.net/modules.php?name=News&file=article&sid=620
LOOK @ THIS:
I can assure you that the information from RCZone is so far off that we are baffled as to where they came up with that info
Adrian will post up coming releases for 2005
Well after a series of rain delays we finally completed our point series at TQ. Happy to say that the schu did me proud as a TQ'd for the first time EVER on friday eavening. Although i was hacked out of my first place position which would have allowed me to take second place in the series, i was truly pleased with how most things went during the event.
Having said the above: I'm now considering participating in the mod class now that I have the ability to keep the car off its roof. So my questions are; what changes are recommened when moving from 19T to Mod as far as setup goes? I see a lot of the good guys just change motors and go but i'm sure the car feel different from class to class. Should i make any belt changes or anything like that? What should i be paying most attention to?
I got me a cobol 9T btw.
Hey,
They need impression PW thats why they writing all that S***(tuuut).
Helo IslandBwoy,
What de most drivers are doing is take out the one-way and put the spool or a locked diff in when they go run MOD, that helps allot!!When i'm running 19T i'm using the grey front belt when you change to MOD use the front belt (black) off a R12.Also dont forget to change your ESC. to Touringcar program. Thats almost all to say.
We have three projects that must be completed before any work can begin on a new sedan.
1. Havoc - Monster/Stunt Truck - .28 engine, 3 speed, super burly suspension w/70mm travel per corner. Sept/Oct 05.
2. Cat 4000 - 4wd Electric Racing Buggy - Mid/rear motor, saddle pack chassis, new hubs/arms, new drive train (not Mi2 style). Dec 05.
3. Top Secret Nitro Truck. Dec 05
you can buy an Mi2 with confidence now as the Mi2 is really flying right now in the US and Europe.
PW Won the 2004 ROAR Nats in 19T and we had 2 cars in the Mod Mains (6th and 9th). If he hadn't gotten hit and broken in the first round PW would have been top 5 in the invite class at the Reedy Race (He ended up 11th). Every time they were in the same race Rheinart (the current WC) could not pass PW.
Teemu is on the Podium in just about every race he has entered this year and recently won the Nordic champs turning faster lap times than Rheinart and Groskamp.
If you always wait for a new car you will never buy one. The day after a new car gets signed off for production work begins on its replacement. There will be a new sedan but if you wait you will be missing out on a lot of good times with an Mi2.
Originally Posted by IslandBwoy
I didnt think about the esc programming. Thanks alot. I'm currently running a gtx which has worked great so far with the most agressive settings (program 6). Should i be changing my mod setup to be less agressive? What changes am i looking to make as far as speedo goes?
P.S.: english is not so good i can make mistakes , sry
TTT
Are the Worlds CVD's for the Mi2 in stock?
I was going to try and convert my front diff into a spool for this weekend race. I was just wondering if someone could post the instuction again. I know it's pretty straight foward. I think it mentions to glue in a shui card . just curious what type of glue do you recomemd(CA).
Thanks in advance
Thanks in advance
hi guys i was wondering you know how thers 3mm and 2mm lower decks what are they used for is one for carpet and one for concrete
Has anyone tried the ackerman link in the outer holes on the steering bellcranks?
I've noticed that in all the setups I've downloaded, everyone is using the middle hole.
Thanks in advance
Thanks in advance
-Weylin
