Schumacher Corner
I did mess with bump steer quite a bit and it does make a significant difference on the track. Going to bump out did seem to effect the entry more and made it dive into the corner harder under braking.
Hey Guy's,
What are the optional chassis' available for the Mi2?? The BMI, the Teemu and is there also another thickness Schumacher Chassis?
And what are the benefits of each?? As my current chassis, has been worn down alot, so am looking to get another. But I do like the adjustable battery position of the original, but I believe the Teemu and BMI are single position's for cells?
Where is a good place to get Schuey stuff from OS? As here in Australia, it's quite expensive and not a lot of people stock the parts??
Iain
Iain
Originally Posted by Iain
Hey Guy's,
Iain
Iain
The Teemu chassis has the cells fixed in the "Back + In" position from the adjustable chassis. It is 2.5mm thick. There is now a 3700 verson of this chassis, i assume the cell position is comparatively the same.
The 2.5 adjustable chassis was never available for sale.
Jon, i do like the look of that "narrow" BMI top deck
Interesting debate on the bump steer adjustment. Haven't tried it, but might be worth looking into, fairly easy to change.
Just letting you guys know that tomorrow is the day that I'm whippin' up on MO and everyone else running the Revo race....LOL
PW paint job will have some stickers on it!
You got some for 19T? Or is it a "no sack" type of thang?
LMAO
LMAO
Originally Posted by mini-dub
Take out the diff balls. Glue one side of the diff rings with CA to a header card. Then just tighten the diff/spool down so it cant spin unless you hit something really hard. Don't over tighten it with a steel screw or you can break the screw (I did that the first time I built a spool) and its a pain to get the broken screw out.
-Weylin
-Weylin
Originally Posted by cyrrus
Just curious how much of the card do you use? Do you cut it to the same size as the diff rings? And you do both sides? I'm just trying to get as much info as I can before I attemp this conversion.
LMAO
LMAO
....BTW.....you're welcome
Hmmmmm.....
I haven't run mod in a long time.......
Hmmmmm.....
If you're running mod....you might want to see if P-DUB offers a rear bumper....
heres some pics of my mi2 its just a stocky but its still good
pic 2
yous have any advice on weater if i should re arrange the placing of the reciever and esc coz ive read that the reciever is ment to be on highger ground than the esc
On the gear ratio's how can you tell what ratio you are running..The pulley 20 or 17?? What is the "stock" ratio,2.12 or 1.8..
