Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 03-23-2004, 04:46 PM
  #5626
stulec52's Avatar
Trader Rating: 26 (100%+)
ah ok.
I did love my TRF shocks though ( on my Evo3 and 414)
But Schumacher shocks have always been good, well at least since CAT2000 days !
Anyone tried the vari pistons?
stulec52 is offline
Old 03-23-2004, 05:06 PM
  #5627
TeamButter's Avatar
Excuse me Mr. Wynn,
Will P-Dub Racing be offering an X-RAY chassis soon?
please advise.
TeamButter is offline
Old 03-23-2004, 05:12 PM
  #5628
Thumbs up
Yeah, I can see it now!!! "TeamButter Edition"
barnacle is offline
Old 03-23-2004, 08:35 PM
  #5629
STLNLST's Avatar
Trader Rating: 32 (100%+)
Originally posted by =MisFitz= NuKe
what?? no i do not think so, I am saying that the stock shocks are fine, like I stated, and that if you build the xray shocks correctly and take you time, they will blow away any shock out there.....as in the TRF shocks are not all that great
how's your testing going? Last weekend made me feel like Masami for a quick second (while the track had traction) The guys that are going to the Reedy race around here are spool and diff testing. I ran the spool with my own little twist on the set up and it was pretty good. I like the pull out of the corners with a spool but I think that the diff might feel a little better in the beginning and middle of the turn. So far I'm finding that the car likes to be set up sort of soft. I'm still playing with different things trying to come up with a basic set up. Good luck and we'll shoot the breeze at the nats.
STLNLST is offline
Old 03-23-2004, 08:39 PM
  #5630
stulec52's Avatar
hey STLNLST
going by what you say about the relative merits of spool vs diff up front, why don't you just run the front diff about a quarter turn tighter??
Best of both worlds !!
stulec52 is offline
Old 03-23-2004, 09:57 PM
  #5631
STLNLST's Avatar
Originally posted by stulec52
hey STLNLST
That will be something that I'll have to try out. Other than foams on rubber no one in my area runs a diff or a spool so getting use to both of them is going to take a little time for me. Which one do you run mostly if you don't mind me asking?
STLNLST is offline
Old 03-23-2004, 10:09 PM
  #5632
stulec52's Avatar
I am currently just waiting on mr postman delivering my Mi2..
But I have been running a TC3 this Winter Season.
Indoor, on Carpet with foams, JACO of course, mostly Double Pink rears with either Plaid or Double Pink/Orange up front.
I run a diff in the front, but I run it pretty tight, gives great drive out of the corners, + has the added benefit of smoothing out the entry into the turns.
Mind you, you do have to balance the rest of any setup to take advantage of your drive setup....
stulec52 is offline
Old 03-24-2004, 07:03 AM
  #5633
STLNLST's Avatar
Thanks for the input. I have some thicker diff grease to try that has been working pretty well for some of the Yokomo driver's so I figure that I'd give it a try as well.
STLNLST is offline
Old 03-24-2004, 03:14 PM
  #5634
lazyboy The schumacher shocks are just fine.I smooth out the variable piston before building with very very fine sand paper. I ran the MI2 for the first time this past weekend and had 2 things break. (1) first the ackerman link was pulled out of one ballcup.(2)I broke a front plastic (stock) driveshaft. Both happened because of my driving. I recomend steel or Ti drive shafts for the front. The rear is good with the stock plastic shafts. This was also true with the Mission.
the shoe is offline
Old 03-24-2004, 03:28 PM
  #5635
lazyboy's Avatar
can anyone post a picture showing how they have there elctonics set up, with or with a personal would be great too
lazy
lazyboy is offline
Old 03-24-2004, 03:38 PM
  #5636
=MisFitz= NuKe's Avatar
here ya go...
=MisFitz= NuKe is offline
Old 03-24-2004, 03:40 PM
  #5637
and the battery side, notice the tabs to solder to are under the deck
Old 03-24-2004, 03:44 PM
  #5638
it is going good, I ran in Austin this last weekend, and won, lol, first time there with the car, we ran mod, so I was using a 9x1. The car was great, although in the main i took the sway bars off, BAD CHOICE. I think I am just running a bit to stiff of shock oil, at 45 and 40 with xray three holes open pistons.
Old 03-24-2004, 03:46 PM
  #5639
lazyboy's Avatar
thanks, it looks really tight fiting for the wires in that car
lazyboy is offline
Old 03-24-2004, 03:58 PM
  #5640
yeah sortof
