Schumacher Corner
#5596
Lift body ?
Originally posted by rcshark
Ratter,
Hi, Im a old racer all my moters are just as fast and do just as good as the fastest guy on the track. I just have to drive concistant laps. I dont thank motors that win races are that much better cause on time into the wall or a slip of the tires makes every one else even. cause 200 rpms is not anough to be seen. and even if every thang is great your car still has to be set up right. know matter how fast we are. if your laps are with in 5/10 of a second of each and every on then yes try fixen the motor if not lift your body! lol
Ratter,
#5597
Re: break in
Originally posted by gkp5569
the trick with sealed can motors is to break them in using low vols <3 volts for a long time 25-30 mins this is cause they have very hard brushes that need to be bedded to get max performance. remember to keep the motor lubed while doing this to. gearing is crucial in 540 class so find out what the local guns are using and start there.
hope this helps
Gary
hope this helps
Gary
is that <3 volts at constant speed for 25-30 minutes and when you say lube it , are you talking the end bushes?
I'm using the same gearing as the local fast guys, but their gearing can vary from 4.39 - 4.67 for similar results, as if their motors have different tourqe/ rpm ranges
#5598
yes ratter
I was at the snowbirds and couldent find my set up and at the end i found out that my body was draging in the turns and was causing me to be loose in the turns. all i do is to break in my motor is us drops and run it on 4 cells and not let it get hot i know some guys that use a slave motor to run in brushes. i dont thank that water and ele. go well together. although i have heard of some guys trying this but its not a common practice. i liked jkp process sounds like your best bet.
sorry for the confusion one the bodie thing
#5599
EA....The testing went well and the material is do in on Monday. The chassis/top-plates will be cut Monday afternoon and I will bring them with me on Tuesday. Sorry we couldn't have them sooner, but we had to wait on material
#5601
What a weekend at the Speedway! 4 MI2's and a Mission in the A main. I finished getting the car together at the track and managed to put it in 7th place!No testing before my first heat. From over steer to push i tryed a lot of different set ups. The car reacts to all settings well.It was fun and with one more test i would have known what was going to work but my practice pack dumped before i could evaluate my last change.It was not the righ change, back to oversteer! Great car and one more thing don't use the stock plastic front cvd shafts go with Ti or steel ones i broke mine. That was the first thing i broke on my mission too ! Good thing the shafts from the Mission fit so i had some on hand.
#5603
Sounds awesome Shoe....guys did well!!!!!
The graphite for the new P-DUB chassis was delayed a day, so chassis will cut later this week and we hope to have the chassis sent straight to the carpet nats
btw: Got a new e-mail for P-DUB Racing Products www.pdubracing.com
#5604
P-dub----will a P-dub chassis find it's way to sac for testing....hint, hint
Spool testing was pretty good this weekend. The tarck conditions were somewaht different than they usually are but in practice and up until the first round of qualifying the car was pretty good. I was 2nd after the first round of qualifying. Mo was first by a couple of seconds. I started to test with traction compound but due to slippery track conditions I don't know if the sauce failed me or the tire's. For the next time out I'll have a ton of new tire's to test with for different temps.
#5607
Hey Clint....I hear ya buddy, but you will have to get in line...LOL
Resumes can be sent to [email protected] or [email protected]
Spool testing.....Must be Reedy Race time
stulec52....Send an e-mail to [email protected] for some setup sheets
#5608
Sup EA.....I fly out at 3:48pm and get in at 6:14pm When you getting in?
#5609
Originally posted by coastaltony
STL
What was the average track temp, and which tires were holding on?
STL
I had sorex 36's on the car when everything went haywire. I wasn't the only one with traction issues that day. Everyone had the same problem. It was just a freak incident and in the four plus years that I've raced there that was the lowest that the traction has ever been.
In the first qualifyier with 92 degree track temps that pit 27 with medium/hard pit inserts were the ticket. My buddy that finished ahead of me that round also had pits on his car. I think that he had pit 36's on. I'll double check that and get back to you.
#5610
SOREX 32's Baby!!!!
