Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 07-10-2003, 05:26 AM
  #4396
TimPotter's Avatar
Trader Rating: 15 (100%+)
I run mine on top of the servo, both on my Mission and my 12th. Our loop is under the carpet.
TimPotter is offline
Old 07-10-2003, 10:46 AM
  #4397
Top of the servo, no problems. Got it sitting on the carbon chassis in my off rd buggy and no problems with that either. Loops under the track.
MattW is offline
Old 07-10-2003, 04:32 PM
  #4398
King-G's Avatar
cheers bigears...
King-G is offline
Old 07-10-2003, 04:37 PM
  #4399
King-G's Avatar
what bearing upgrades have we all tried on our Missions...
I totally recommend the Tamiya Blue seals for the Diff mounts...these are the best bearings full stop!..amazing precision...they have funky ball cages, non metal, like a plastic or composite...very free and quiet...and excellent seals.
i have been using Accer dual polyamide bearings in the hubs and layshafts..not totally sold on them, as Ive had a few seize up...I fel that the only difference from the Kit bearings is the seals..(dual Polyamide), the races arent of the best quality.
I have just installed some ceramics in the layshafts, will see how they go.
has anyone used Boca ceramics on their mission>?, or other brands for that matter?
King-G is offline
Old 07-11-2003, 12:58 AM
  #4400
Ian S's Avatar
Ive tried the Acer bearings all round and wasnt too impressed either altho they were an improvment over the year old kit bearings! The bearings that come with the new mission kits have blue seals like the tamiyas but i havnt seen any myself, ill have to get some to try.
Ian S is offline
Old 07-11-2003, 01:08 PM
  #4401
Default Measuring Droop
How does everyone measure droop? Do you measure from the kingpin or the "fat" part of the lower arms. Do you set zero point when the arms (especially the rears) are parallel to the bottom of the chassis?
Sydewynder is offline
Old 07-13-2003, 07:10 AM
  #4402
Ian S's Avatar
Im not sure how everyone else does it but i measure the ride height then lift the car untill the tyres are just touching the set up board and measure the height of the car usuing the ride height gauge, the difference in the 2 readings is the droop.
Ian S is offline
Old 07-13-2003, 08:32 AM
  #4403
Racer X's Avatar
Measuring Droop: I believe most people measure it by taking off the tires and placing the car on a flat surface. Using a ride heigth gauge, measure from the surface up to the bottom of the arm where the hex screw attaches to the hub. The smaller the number, the larger the amount of droop (4mm is less droop than 2mm). Either this or they use the Hudy blocks.
Racer X is offline
Old 07-13-2003, 01:46 PM
  #4404
what size should i make my shocks for the setup pw posted?
jiggamacdaddy is offline
Old 07-13-2003, 02:15 PM
  #4405
ottoman's Avatar
Anyone hear any rumors about a new car? A guy told me that at the Roar on road Nats he heard the word (shaft drive) from someone at Scumacher. Probably just a rumor but I hope there will be at least some updates on the Mission... seems like all the indoor racing is going foam tire and thats not the Missions strong suite.
ottoman is offline
Old 07-13-2003, 05:20 PM
  #4406
The updated car will be out in October from what I have heard, as for it being a shaft car not sure that will happen anytime soon.
XCELL is offline
Old 07-13-2003, 05:38 PM
  #4407
Has anyone else used the Xray rear belt on their cars? I have used the older Xray belt for a long time now and just got the new 3mm belt, vert nice.
XCELL is offline
Old 07-13-2003, 06:05 PM
  #4408
im selling my mission, mint condition, lots of upgrades, lots of spares! only $150!! take a look in the For Sale Forum!!
nate
Ih8 RiCeRoCkEtS is offline
Old 07-13-2003, 07:21 PM
  #4409
Trader Rating: 22 (100%+)
Hey Paul, what mod's do u need to do to be able to run 28 and 30 mm tires.... i know there was talk of a new spindle that would allow you to run the wider tires but i havent heard anything else about it.
Bob Barry is offline
Old 07-14-2003, 10:53 AM
  #4410
PW
PW's Avatar
Bob Barry.....Yes, we have hubs that allow the use of 30mm foams on all of our sedans. The part number is U2581 and the only change will be that the turnbuckle link will need to be shortened accordingly.....
PW is offline
