Schumacher Corner
#2896
PS , I like to use Silver front and Green rear.
#2897
R/C Tech Elite Member
Re: Front belt on Mission
Originally posted by FTD RACING
I have just purchased a second hand Mission today. Have seen them going fast at my local track and thought it was time to try something diff.
I have noticed that the front belt is very tight, it doesn't even use the belt tensioner. Is this normal? It has the standard belts on it. Any tips on making it a bit looser?
Also, what effect does useing the in-board toe in front and rear?
Thanks for helping.
Thanks for helping.
#2899
Ide just call up Adrain and ask him.
#2900
Impactplayr,
Black 6lbs
Grey 10 lbs
Blue 15lbs
Red 20 lbs
Yellow 25 lbs
Silver 35 lbs
racerdave
Black 6lbs
Grey 10 lbs
Blue 15lbs
Red 20 lbs
Yellow 25 lbs
Silver 35 lbs
racerdave
#2901
Go with Green!
#2903
Trader Rating: 32 (100%+)
I personaly like the Losi springs over the Associated. The Losi springs feel better and the car seems to work better for me when I use them over Associated springs. The Associated springs seem to get too stiff the deeper in the movement of the spring and the Losi are more constant through out the whole compression range. But what ever springs you can get or work for you run them.
#2904
Re: Re: Front belt on Mission
Originally posted by heavy
FTD. Make sure that the Layshaft Mounts are correctly installed. If you don't have them teh correct way to suit whichever layshaft pulley you are using then you can end up with a loose rear belt and tight front belt. Check your manual page 7 for the correct orientation of this part - very important
I can't believe I didn't think of that.
#2906
does anyone have a stock/mod setup for high bite asphult?
And gearing as well, I race at socal raceway which is a small to med size track.
thanks
thanks
#2907
here is my setup for asphalt
Front-
Shock Piston-2
Spring- Associated Red
Oil-45 WT
Diff-One Way
Camber-1 1/2
Toe-0
Castor-2 small kwik clips
Tires-Sorex 36r With Blue Inserts for day & Cs-27 at night (Depending on track temp, 36r-82-98 degrees, cs-27 75-82 degrees) Tires Depend on Track Temp. I Used srex 36r and the whole car stuck like glue.
Rear-
Shock Pistion-2
Diff-Diff
Spring-Associated Gold
Oil-45 WT
Camber-1 1/2
Toe- 3
Castor-3 Med.size Quick klips
Tires-36r
Motor-Trinity p2k2
Body-Trinity Stratus
Gearing- 17t pulley, 25 pinnion, stock spur
Hope this helps. This is a p2k2 setup, Car is Extremeley fast. I won got 2end in my first heat and 1st in my seconed heat.
Hope this can help yall out
Front-
Shock Piston-2
Oil-45 WT
Diff-One Way
Camber-1 1/2
Toe-0
Rear-
Shock Pistion-2
Diff-Diff
Oil-45 WT
Camber-1 1/2
Toe- 3
Tires-36r
Motor-Trinity p2k2
#2908
thanks I will give it a try on sat
oh and about the pully I have been using the 20t, is the 17 better for stock?
#2909
Well, I hear that 20 is a little faster than the 17. But my car has tons of motor over all the other guys cars so its about the same for me. But my gearing is with the 17 so ide install the 17. What motor u using?
#2910
From the info I have collected from running the Mission with the 20 and 17 tooth pullies is that with the same final gear ratio the top speed of the car is the same. The difference is that if you use the 17 tooth pulley it will get up to speed faster than the 20 tooth pulley. It all depends on your track layout. If you run on a long flowing track, use the 20 tooth. If it is a short track, use the 17.
James Nguyen
p.s. Garrett, you don't have motor on me....hehe.
James Nguyen
