Schumacher Corner
PW
when will the p-dub bumper for the mi3 release, also what are gearing check point motors to rubber
Originally Posted by stephen hilton
hi does anyone know what bearings come with the mi3?
FYI, they come oiled not greased so the drivetrain is super free right out of the box.
There will be a special Mi3 PDub bumper. PW will get the info out when he know more details.
Originally Posted by AdrianM
The Mi3 will come with the yellow polyamide seal bearing that the Mi2EC came with. They are really good. So good that most of the team runs the stock bearings and never bothers to install the ceramics.
Regional Moderator
Originally Posted by PW
They actually did that to allow extra room for the receiver since it's so tight. I'm not a fan of it either, but I run DSM so no problem I'm sure we can come up with a easy solution
I've seen pics of the early version of the car with the LRP Sphere and DSM mini receiver mounted.(I think it may have been a pic of your car) and I saw the little DSM wire sticking up. I guess that definitely solves the antenna mount location thing.
I look forward to seeing what solution you guys come up with. Maybe something as simple as having a way to mount the antenna mount to the rear servo mount post or something like that.
Originally Posted by seaball
these little sluts are awesome. best bearings i've used to date. infact, i replace my ceramics with these! okay, that's a lie. but these things are really that awesome.
R/C Tech Elite Member
Originally Posted by dawgmeat
PW
PW
I personally alway start a 7x1 at 9:1 with 12*deg of timing. After the first lap down the straight I know if the motor needs more or less gear. The most important thing I've learned with any modified motor is to NOT under gear! Once you under gear a mod motor it will over-rev and go out of balance
Originally Posted by Randy Caster
What turn and what track size?
my bad about 90x40 19-turn
The Evicerator
Wow, PW and Randy together are like the Internet Answers 1-2 punch team!
HA...Funny guy!
Please explain why Novak equipment is orange...
PW, did you get my email from last night? Just wondering if that'll work alright for you.
I would probably start with a 6.0 for a small track. On some of the bigger tracks we run on the FL State Series we are in the mid to upper 5's with the Checkpoint Money Motor
The Evicerator
Legend says that it was so you could look at a car's guy from across the pits and see that he was running a Novak ESC... not just some non-descript black box
