Schumacher Corner
R/C Tech Elite Member
We have taken the 96t spur and made it our total priority right now.
We don't have a definite date yet, but were looking at 20-22nd of this month.
Trust me, you'll all know the second we have them
~ proper preparation prevents piss poor performance ~
i propose that jaybee (sweet jerome, as he likes to be called) goes over every team driver's car before each big event. new mounting, new wiring, and whatever balancing he deems necessary. it should be mandatory that all team cars look like (or near) those that jaybee has shown us. simply awesome, sir.
then, the cars will be shipped to randy caster (aka - randall 'the vandal' caster) , where he will properly shim and align them.
meanwhile, mcgoo's painting up shells for each of us (since jaybee's already busy stripping wires) ...
finally, the finished package will meet their owners at the race track, ready for battle.
so, what do think about this adam? can you mandate this? we'd be alot better off, let me tell you. instant demotion/suspension for anyone caught with a rat's nest or air in their shocks? what do you think?
get too it.
Hmmmmm....
By thse rules I'd not be allowed to run the car....
After further review that may not be a bad thing after all...
i bet a corally layshaft pulley assembly would work, with 35t diffs (so the c-c distance would be the same). and... that would help gear the car up for brushless (internal drops to 1.67). worth a try. might need a longer layshaft, which should be a piece of cake (every standoff the industry seems to be 5mm od.).
get too it.
get too it.
How soon before the manufacturers start releasing "brushless" pulley and belt kits to drop the internal gear ratios for these wacky FDRs we all need now?
won't even need belts if you add/subract the same # of teeth. 24/32 (1.33 int.) would probably suffice. and that would get our belt off the pinion and top deck more.
Super Moderator
get too it.
get too it.
posting frenzy
sidenote: a 24t layshaft pulley would probably have a large enough diameter to use standard spur gears. now that's about 7 solutions in one (okay three-ish).
beat that schumacher! (but i'll settle for matching it!)
Then they could sell more of those 114T spurs :P
Who's "adjusting" who in that pic Tony? lmao
Super Moderator
