Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 12-01-2007, 09:22 PM
  #23536
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Originally Posted by Solara
Can someone share some pictures of your Mi3 with Novak GTB layout for reference..? I am trying to mount 1 now and I want to get some ideas from you guys...thanks.
Marcos.J is offline
Old 12-01-2007, 09:23 PM
  #23537
Super Moderator
Marcos.J's Avatar
and if you are running 5 cells
Marcos.J is offline
Old 12-01-2007, 09:33 PM
  #23538
Trader Rating: 17 (100%+)
Macro....you read my mine. Nexus and I are thinking about testing 5 cells 13.5. I really think if that can last 5 minutes, the car (feeling) will handling a little bit BETTER then 6 cells. On my Mi2EC, I always find the extra power of the 13.5 a waste....can't really used that extra power on tight carpet track. May be with the 5 cells, I can MAX out the car....
That spectrum mini receiver must be REALLY small....can barely see that on your 1st pic.
Solara is offline
Old 12-01-2007, 09:41 PM
  #23539
Jon Kerr's Avatar
If you're going to run the LRP, here's how I wired up for 5 cell.
Jon Kerr is offline
Old 12-01-2007, 09:47 PM
  #23540
Thanks JON....I am still trying to figure out how to "CLEAN UP" those wires from Novak GTB....I wish I can CUT them all and solder them direct onto the speedo...LOL
Also Jon, what is the advantage of using the wider (thicker too..?) upper carbon deck...? Rubber carpet and or foam carpet?
May be I should work on the batteries...pick the dead cell out from the IB 4200 that I have = 5 cells ready.
Solara is offline
Old 12-01-2007, 09:57 PM
  #23541
Big Features's Avatar
Ran the Mi2EC at the 1st ever rubber-tire carpet race at "The Track" and qualified 4th and ended up 7th after a brutal "A" main. I have the fastest Schuie there and it was the OLD car!! If your thinking of selling yours, DONT.
I'll be running it at the 'Birds
Big Features is offline
Old 12-01-2007, 09:59 PM
  #23542
I TQ'd Stock foam and then the neck bone snapped.
Brian Regal had a fast call all day, and Tom Kaiser was out with his new ride. Even had some pritaveers in the house. Very good day for Schumacher
Old 12-01-2007, 10:00 PM
  #23543
Jon Kerr's Avatar
Neither. Rubber tire asphalt. It's the same thickness. Just a double ladder bar instead of the stock single deck. I like running it because it seems to keep the car from tweaking. I don't think it's really a whole lot stiffer. Just holds better.
Jon Kerr is offline
Old 12-01-2007, 10:05 PM
  #23544
Definitely NOT planning to sell the Mi2EC....car is still fast and great. It will be my 4 cells Trans Am car and or foam car.
Jon...thanks for the upper deck info. I have extra Mi2EC Foam upper deck laying around and was thinking about cut it short and fit it onto the Mi3 for FOAM use...those holes are the same, except need to drill 2 more after the cut.
Solara is offline
Old 12-01-2007, 11:23 PM
  #23545
Customworksking's Avatar
Trader Rating: 74 (100%+)
I can't get my diff tight rebuilt it by the book checked everything 3X bearings ,washers c clips no matter what it will not get tight?
can someone help me on this I rebuilt 3 and only 1 will not go back right
Customworksking is offline
Old 12-01-2007, 11:30 PM
  #23546
Guys I run stock rubber on ashphalt..I have mounted the flexy top deck ON TOP of the origional...man it sure stiffens the car up and no more broken top decks!!!!!
Barger is offline
Old 12-02-2007, 02:17 AM
  #23547
woozer71's Avatar
Trader Rating: 23 (96%+)
I know it might be somewhere in this thread, but could I ask where you can purchase the Core 5000 lipo from?
Matt
woozer71 is offline
Old 12-02-2007, 03:37 AM
  #23548
check the thrust washers one is larger in diameter, put the smaller one at the bolt head first.
Besercoe is offline
Old 12-02-2007, 04:16 AM
  #23549
Skiddins's Avatar
Matt
Schumacher;
http://www.racing-cars.com
Skiddins is offline
Old 12-02-2007, 06:20 AM
  #23550
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
Yeah thanks for my beat down. Klings rubber tire EC was money tonight and had mad rip. His foam car was awesome to.
Kiaser was out early but hsi car wasn't bad for only running it 3 runs total so not sure of the problem. We also had Ticle a privateer show up with his MI3 and while he is new his car looked good so now it is just some practice at the tough track we raced at tonight.
wyd is offline
