Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 05-08-2007, 08:58 AM
  #18856
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Originally Posted by wallstreet
http://www.superiorhobbies.com/istar.asp?a=6&id=SCHK073!SCH&csurl=%2Fistar%2Easp% 3Fa%3D3%26dept%3D07%26class%3DKIT%26subclass%3DONE LE%26
Dawgmeat this is a present for you
Notice the status of the kit "IN STOCK"
dont get him started he will blow a gasket!!! let him read the red print "pre-order"
Marcos.J is offline
Old 05-08-2007, 08:59 AM
  #18857
Super Moderator
Marcos.J's Avatar
Originally Posted by dawgmeat
Fast track where mu GOTDAMM Mi3
is at my house
Marcos.J is offline
Old 05-08-2007, 09:03 AM
  #18858
dawgmeat's Avatar
Originally Posted by Marcos.J
is at my house
I glad adultfriendfinder has been strong with me all the fat girls keep my mind off of the Mi3
dawgmeat is offline
Old 05-08-2007, 09:06 AM
  #18859
Super Moderator
Marcos.J's Avatar
thanks for sharing that info with us!
Marcos.J is offline
Old 05-08-2007, 09:27 AM
  #18860
"That's some Rich Stidham type stuff.....LOL ROOKIE!!!!"
now stillverylast, thats just wrong,,,no matter how i resemble it thats not nice how is the new car coming along?
gdcopbdcop is offline
Old 05-08-2007, 10:46 AM
  #18861
StephenSobottka's Avatar
Originally Posted by EAMotorsports
Wow...You do know that being on the "team" and an avid carpet racer you MUST endure the Chris Goetz induction right?
EA
I feel my butt is in serious jeopardy all of a sudden...
StephenSobottka is offline
Old 05-08-2007, 11:31 AM
  #18862
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
is at my house
wyd is offline
Old 05-08-2007, 12:41 PM
  #18863
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Lightbulb Schumacher Lipo
Adrian/PW: any news on the Schumacher 5000mah Lipo? Will it be out by this year? Where are the connector going to be? Dimensions, weight? Price range?
yyhayyim is offline
  #18864
Super Moderator
Marcos.J's Avatar
the connector will be at the near corner of the center's middle-right side (but inverted)!!
Marcos.J is offline
Old 05-08-2007, 01:35 PM
  #18865
The Shrew's Avatar
The Mi3 driveshafts are rubbish !!
Would the Mi2 ones fit ?? I belive the steel ones work ie dont bend or break. Or are the titanium ones ok ?
The Shrew is offline
Old 05-08-2007, 01:44 PM
  #18866
AdrianM's Avatar
The Mi3 and Mi2EC drive shafts are the same (U3020). The Steel MIP units (U2151) are very easy to bend. If you are having a problem I suggest you contact Schu UK instead of posting here as no one here can send you replament parts
AdrianM is offline
Old 05-08-2007, 02:08 PM
  #18867
The Shrew's Avatar
I will be in touch when they open in the morning. I was asking because i wanted to try and fit ones that were strong enough. Not replace with the ones that are in there now.
Having said that with the little time i had on the track with the car i must say it was very good was more than happy with it defo worth the wait. Especilly when it had 4 wheel drive !!!
Old 05-08-2007, 05:55 PM
  #18868
yyhayyim's Avatar
Superior Hobbies in Orlando, FL says they have 4 Mi3's in stock Is this for real? If its true, how did they pull off that trick and get them in before Fasttrack and Speedtech RC?
yyhayyim is offline
Old 05-08-2007, 06:14 PM
  #18869
Trader Rating: 264 (100%+)
I could be wrong but I think that means they have 4 more preorders left.
Fred Perkins is offline
Old 05-08-2007, 06:18 PM
  #18870
hey guys got a few questions bout applying the stuff adrian said bout the mi3 to and ec.
my diff pulley wont come apart so i cant take off the fine ring before i cut it off is there any reason u would leave it on? also whats the shim spacing with a oneway in the front and a diff in the rear?
finally is 1/8th of an inch the same as 3mm? just i cant find a 1/8th reamer?
on a different note how many degrees of steering do u have? on a hudy system i have about 15 to 20 degrees is this about right?
cheers guys
aus jd 2703 is offline
