Schumacher Corner
Hiya
The only 2 types of shock adjusters that i can get are Tamiya and Xray ones. As it was stated above that the tamiya ones are a bit small, will the xray ones from the T2 work on the schumacher EC shocks ?
Originally Posted by MoonTrap
Hiya
FYI, I have been racing the Mi2EC with the stock shock collars for over a year. I have NEVER had the collars move during a run. This is a case of fixing something no one has a problem with. Yes they are a little loose on the bodies but they will not move unless you move them.
Form Help
Hi.
I'll be receiving an MI2EC any day now from an auction I won -I can't wait to start running this car. For those of you that know this thread well, can you send me a link back or tell me ~what page in the past the form starts focusing on the MI2EC. I don't have a lot of time to wade to over 500 pages of information. Thanks!
I haven't had any problems with my stock collars either. Except if I hit them when making adjustments to the links or something. I've heard someone say to score the threads with a knife to keep them from turning freely.
Originally Posted by AdrianM
The tamiya plastic one will fit . I dont know about the xray ones.
XRAYs won't fit either.
wyd
im running 1mm above the cf riser with no diff spacers.
white springs, 30wt oil all round,1 degreee camber, 4 degrees caster 1 degree tou out on front standard rear and all in links in top standard hole and an extra 1mm on the out rear camber link.
droop im unsure as ive had trouble getting consisten measure ments
Tech Legend
Trader Rating: 51 (100%+)
Originally Posted by aus jd 2703
wyd
To find your droop put a batter in your car and set you ride height to 5mm. Then keep you ride height gauge thier and slow raise the car like from the center of the chassis. When the wheels come off the groundcheck the ride height. The differance between the two is your droop. So lets say you have 5mm of ride height and your wheels come off the ground at 6.5mm you have 1.5mm of drrop.
I use the associated blue alum ride height gauge.
Tech Legend
Pic of my new Speed 6 body on my MI2 EC.
BTW Brian I'll have my EC in 2 days.
Tech Legend
Originally Posted by TVMRocket69
The Rainbow Warrior.
Question. Do the CVD's for the MI2 fit the EC.
Tech Legend
Originally Posted by RC Old Man
SWEET! I need some new bodz!
Tech Legend
ive just seen those pictures of the mi3.it looks like one step for schumacher and one giant leap for the racing brigade. very nice
all the lastest touring cars are designed and built to such high standards and due to this rc racing at all levels are going to rep the benefits.
i think its going to bring much more exciting racing at world level as the all the manufactors have closed the gap on the brand that sort of broke the mould.
with the playing field levelling out i do look forward to seeing a british car rule the roost.
when is the car due to make its appearance ??
