Schumacher Corner
Tech Legend
Trader Rating: 51 (100%+)
Originally Posted by aus jd 2703
bout the only problem is that the car has a higher centre of gravity which imo helps on aphsalt where grip is low and a bit of roll can increase grip.
but i reckon the mi3 if thats what they call it will kick ass.
ok im about to go from a track where i run 5.5mm and 6mm ride heights to a track that is bigger and slightly smoother, what can i expect to change to get the car handle similar? ill be lucky if i can put 2 pack in before we start qualifying so im trying to plan out what i might need to change.
cheers guys,
Josh
cheers guys,
Josh
97-03.
Originally Posted by mini-dub
Just drivers testing new parts, we always get a lot of parts from the Team Dremel department .
I dont know, MI2 was alright, but MI3, now that was pretty awesome, though it sucks that felicity had to die so early on. How she dies was pretty whicked-in a dark kind of way.... but I dont know about any Dremels being used, though there were those cool explosives with electro magnets on them.
What are we talking about?? I'm easily confused.
Tech Legend
Roll Center ?
Adrian I'm trying your suspension setup you posted awhile back and have a question on it. In the front you have 2.75mm roll center, does this include the riser plate under the suspension arm as part of you total roll center height?
If you leave the suspension riser and add 2.75mm roll center to that the suspension arm hits the bottom of the steering arm. I'm going to keep building but go with 2.75 overall counting the suspension riser plate.
OR if anyone else tried this setup and can help that would be cool as well.
Brian
Brian
2.75mm is overall. So the 2mm riser and .75mm shims.
Tech Legend
Anytime
hey guys, just had a quick question...i own a Mi2 with the original shocks, the collars on those shocks are prone to moving and not staying set, just wondering if the collars from the newer Mi2 EC shocks are a bit better in having an o-ring inside them keeping them set?
Actually no. The collars on the EC shocks are very loose. I use JRXS collars since they match the shock body. You can also get TRF or HPI/Hot Bodies. All of them have o-rings and fit just fine.
I just put a thin coating of medium CA on the inside of my stock EC collars and they've been great. On my other race car I have tamiya collars off a set of tamiya shocks that work just as well, but they're plastic so there's more friction in them without any CA. Lots of people run the HPI ones because they work great and are purple . But if you want to save a little bit of money you can use a small amount of CA to tighten the stock ones up. Remember... CA is the duct tape of RC .
part # for the hpi...thanks for the help guys
thanks once again for your speedy help...now the search begins for them collars
