Ask Paul Lemieux, RC America/MOTIV/Gravity RC
#1876
Adrian, fight the urge to anodize that car purple. It will be .3 quicker in orange .
Hey Paul, It's Adrian from back in the day...lol!
I am starting racing again and I have a T3 2011. I was wondering why most of the setup for the T3's run heavy oil and sometime one hole pistons? All the sedans are so similar now and everyone else runs light oil and 3 hole pistons. Springs seem to be similar between Xray and everyone else.
Do the shocks have a lot of blow by, or are the piston holes big? Just trying to understand.
Good luck at the IIC, always pulling for you bro!
#1877
Trader Rating: 32 (100%+)
#1878
Good job in Vegas. Looked pretty good out there with the new car. I have a question about gearing a TP4.5t at mikes in porter Texas. What would you suggest running gear wise. I run a T3'12 with an orion r10. That track seems huge and don't have a vlue where to start. Thanks.
#1879
Paul, I'm running a T312 in VTA. I need to add about 150 grams to this thing to make weight. I already have the 30g center weight installed. I do not have a fan installed but probably will just to have some weight in there that is being used. So where should I put all the rest of the weight?
#1880
You can add the hard bumper and that is good for a few grams. I had to add then, and a bunch of stick on weight to get mine to make weight.
#1881
I left it with Eric. my sorry
Good luck!
#1882
TP 6000 65C 2cell
Hi Paul on my TP lipo 6000 65C 2cell a fully charge battery after 1 qaulifier i normally consume over 2200 mah is it normal ?, I have the battery about six months, Im racing 17.5 blinky i charge it 9900 mah, 10A using my TP820CD.
jojo
jojo
#1886
Hey Paul, what were your initial thoughts to the T4?
#1887
see ya
The car is good for sure. it tunes a bit different so it will take some time to develop the best set ups. the first run on the track with the production car in vegas it was REALLY fast but a bit too much steering for me, after that i made some poor tuning decisions but im definitely excited for it.
#1888
Hi Paul.
Any chance of you putting the setup from Vegas that you ended up with?
I'm trying to look into as many setups on the new car as possible to see how things differ.
Any info on the setup sheet as to which part of the handling you think would need to be changed as well would be great.
Skiddins
Skiddins
#1889
The T4 being a lower cg car does this make role center changes have less effect on the car vs same changes on a T312 ? I will be wrenching on both soon(my T4 and my sons T312)
Some set up theory between the 2 would be helpful . One more thing , I run shorty packs( pro match 4000/70c) with xxs ESC on battery side , I made a weight to mount under belt area to get car weight correct . What I've noticed is the car seems to have more corner speed and makes correction changes faster . Is this to be expected with this set up ? Btw u coming back to drews race in Jan ? Always have a great time running with u guys
#1890
Hi Paul.
Skiddins
Skiddins
Hi Justin. Yup I am planning on coming back to Drew's for the race. we are just cracking the surface on tuning the car so i don't know for sure about the effects of a roll center being less but it would make scene if that ends up being the case. The car definitely tunes different. especially In the rear to me, camber links and shock position in the rear reacts a bit different to my normal feel. Good info on the shorty pack. Thanks
See ya!
