Ask Paul Lemieux, RC America/MOTIV/Gravity RC >
Old 06-15-2012, 10:28 AM
  #1726
Trader Rating: 47 (100%+)
Paul jus picked up a WC NT1 was looking for a base set-up for most tracks if you had one mostly will be running down at LESUIRES HOURS..
Andrew
transplantlife is offline
Old 06-15-2012, 11:09 AM
  #1727
djnsayne's Avatar
Paul,
I race blinky tc and I was wondering what color should I paint my body to be fast enough to beat Drew Ellis and Fabio.
djnsayne is offline
Old 06-16-2012, 07:17 AM
  #1728
Gravity RC
Originally Posted by djnsayne
Paul,
lol, dusted white is the fastest
Andrew
Hi Andrew, the set up for the NT1 has become pretty simple, you want to download either Ralph or my set up from 2012 Ft myers winternats, that is the base set up. from their you will want to run Blue rear and pink front springs when the track is loose, and when the track has good bite you will want to go back to the pink rear and red front as i think the set up has.
Paul L is offline
Old 06-16-2012, 08:02 AM
  #1729
Hello Paul, Thank you for taking the time to do this for us.
uatemycookie is offline
Old 06-21-2012, 02:05 PM
  #1730
Trader Rating: 73 (100%+)
Hey Paul, two questions for you:
When running asphualt compared to carpet for touring car, do you find a big difference with shock oil? Do you need to change oil from thick to thin for every track or is there a wt that works well for most? Thank you
Tekin Prodigy is offline
Old 06-21-2012, 04:00 PM
  #1731
Gravity RC
Hi. I normally use pretty similar shock oil on carpet and asphalt. Normally for asphalt i will set the car up more aggressive because the cars tend to push a bit more. Many times I will use a very similar set up on asphalt as i would on carpet with the main change being that i will usually run the car more rear heavy on asphalt.
No problem
Paul L is offline
Old 06-21-2012, 09:54 PM
  #1732
Kwikvdub's Avatar
Trader Rating: 100 (100%+)
Default Shock maintain
Kwikvdub is offline
Old 06-21-2012, 09:56 PM
  #1733
Kwikvdub's Avatar
Default Shock rebuilding......
Hey Paul, about how many times would you say you build your shocks?...... Once every other week or every week?..... More on carpet than asphalt?
Thanks!
Kwikvdub is offline
Old 06-22-2012, 06:50 AM
  #1734
Gravity RC
Thanks!
Hi Alex. I pretty much rebuild my shocks before every big race, then obviously again any time i change my oil. so if you want to put it on a time line maybe once a month. when rebuilding, the best way is to replace the bladder and o-ring.
Paul L is offline
Old 06-22-2012, 11:54 AM
  #1735
Kwikvdub's Avatar
Thumbs up
Thanks Paul!.... All the best!
Kwikvdub is offline
Old 06-23-2012, 01:52 PM
  #1736
Little question.
On the pre-worlds did you use standard piston holes in your shocks.
Or different hole diam's
Pre thanks for pre-world answere.
Ed
eded1 is offline
Old 06-24-2012, 08:58 AM
  #1737
Gravity RC
Originally Posted by eded1
Little question.
Ed
Hi Ed, 3 hole 1.1. Thanks
Paul L is offline
Old 06-24-2012, 02:24 PM
  #1738
Trader Rating: 16 (100%+)
Default motor timing
I am running a 17.5 in blinky class 1/12 pan car. What do you recommend setting the timing on the motor itself?
mupchu is offline
Old 06-24-2012, 02:54 PM
  #1739
I will traying this, thanks for replay
Ed
eded1 is offline
Old 06-24-2012, 03:41 PM
  #1740
andrewdoherty's Avatar
Trader Rating: 49 (100%+)
Ed
Std holes are 1.0, right?
andrewdoherty is offline
