Ask Paul Lemieux, RC America/MOTIV/Gravity RC
#1651
if you are thinking about getting in to racing, post where you live and someone will inform you on your closest track so you can go check it out and get a closer look.
Thanks for posting!
paul
#1652
Paul Im running the 17.5 motor with the green rotor with with 3.23fdr what would be the most timing i should run on the motor.
#1653
If you are settled on that gear i would start at only 15deg and go up on timing incrementally as long as the motor temp is ok.
#1654
Running at leisure hours straight is im guessing from 200ft to 225ft depending on the lay out. Or am I better of with the red rotor.
#1655
#1657
#1660
Thanks Guys
#1661
Paul, I know you cant let much info out, but will the people be able to look forward to a new XRAY model after the worlds this year? Also what do you think would be a good starting point for outdoor parking lot asphalt sprayed with grape soda. I've never ran there before and i want to try to get close, Thanks.
#1662
I'm sure we will know more after all the big asphalt races coming up.
As for the set up, I would start with my Jackson set up from last years nationals. I think That is the last time I ran asphalt, your car was good their too.
Thanks!
#1663
Hi Randy. Based on history you can expect a new kit sometime late summer,
Thanks!
Thanks!
#1664
Paul, I put your setup on before the 3rd round of qualifying, It was still a little pushy probably because of the tires, however i qualified 6th in the A-main and after making a couple small tweaks to suit the stock class better with the setup, I managed to move into second and close in on the first place driver. Thanks for the help!
