Xray T1
Hey does anyone have a pair of yellow springs?
Well the race was a huge success. We had 62 racers with 116 cars. I had trouble with my T1FK04 with rear traction. after 2 qualifier rounds I tightened the front diff and stood the front shocks up 1 hole and got the rear bite I needed. Now with the rear end sticking good I needed to add more steering travel. Unfortunatly for the main I still did not add enough steering and had a hard time in the corners.
Here is a link to some pictures from the race.
http://s738.photobucket.com/albums/x...k%202011%20CE/
Wow... sounds like you had a blast man... sorry about the handling issues though... do you only run this car on carpet? and if you do... any additives? I am still trying to work out traction on a asphalt surface that nitro cars are mostly run on... very challenging... I was thinking of using additives to help a little... what do you think?
WD-40??? really? have you tried this yourself?...
awesome t1
Yes, I have used it on both rubber and foam. I also have used suntan lotion on foam tires.
Indoors I use Jack The gripper (club rules for the smell)and I only used it on my rear tires on the T1FK04 to help get the rear end stuck. Outdoors I use Paragon black.
very interesting ... wow... definitely will give it a try especially if it will reduce the effect of dirt sticking to the tyres...
No, it will not help with dirt sticking to the tires, it will make the rubber soft and sticky. When our club runs outdoors, we clean the track with a large gas leaf blower and then spray the track with sugar water. The sugar water helps keep the dust down and is sticky to add traction.
Oh... understood... Our track is actually prepped in the same fashion too... hmmm... I'm going to try and and find a good bottle of 'stuff' and hopefully get my hand on a tyre warmer soon...
The front of my car is about 8 grams heavyer than the rear. I moved the shocks out one hole to try and remove a bit of grip in the front. I think tightening the diff had more efect.
tried softer rear springs yet? i tried it and really makes a difference, even though shocks are kinda straight. the rear end really sticks.
After my adjustments, I had so mutch traction that I would traction roll in the corners. The yellow springs I have in the back are the softest ones I have, 14lb. I may have gone a little too far so now I will try to fine tune it.
