Old 01-09-2011, 06:23 PM   #12496
Trader Rating: 25 (100%+)
Hey does anyone have a pair of yellow springs?
jonnymorrow is offline   Reply With Quote
Old 01-10-2011, 01:27 PM   #12497
BCbud's Avatar
Trader Rating: 37 (100%+)
Originally Posted by angry-alien View Post
interesting... let us know the results when you run it...
Well the race was a huge success. We had 62 racers with 116 cars. I had trouble with my T1FK04 with rear traction. after 2 qualifier rounds I tightened the front diff and stood the front shocks up 1 hole and got the rear bite I needed. Now with the rear end sticking good I needed to add more steering travel. Unfortunatly for the main I still did not add enough steering and had a hard time in the corners.
Here is a link to some pictures from the race.
http://s738.photobucket.com/albums/x...k%202011%20CE/
Xray NT1 - Xray T4 2013 TC - Xray T4 2013 VTA - CRCgenX10 - CRCgenX - CRCgenXi - Slash 4X4 with LCG conversion -Associated RC8Be - Xray XB4 - DX3R PRO
Recycled teenager.
www.irocc.ca ; www.corvictoria.com ; http://www.wcics.ca/
I will not send Pay Pal as a gift or add fees to the price so DO NOT ASK!
BCbud is offline   Reply With Quote
Old 01-10-2011, 02:38 PM   #12498
angry-alien's Avatar
Wow... sounds like you had a blast man... sorry about the handling issues though... do you only run this car on carpet? and if you do... any additives? I am still trying to work out traction on a asphalt surface that nitro cars are mostly run on... very challenging... I was thinking of using additives to help a little... what do you think?
angry-alien is offline   Reply With Quote
Old 01-10-2011, 02:45 PM   #12499
UrabusDenis's Avatar
Of course use aditives Try to find tyre aditives from e.g. LRP , also a basic can of WD-40 will do a very good job
UrabusDenis is offline   Reply With Quote
Old 01-10-2011, 06:42 PM   #12500
WD-40??? really? have you tried this yourself?...
Old 01-10-2011, 06:56 PM   #12501
Trader Rating: 16 (94%+)
awesome t1
perez62682 is offline   Reply With Quote
Old 01-10-2011, 07:19 PM   #12502
BCbud's Avatar
Yes, I have used it on both rubber and foam. I also have used suntan lotion on foam tires.
Indoors I use Jack The gripper (club rules for the smell)and I only used it on my rear tires on the T1FK04 to help get the rear end stuck. Outdoors I use Paragon black.
Recycled teenager.
Old 01-10-2011, 07:50 PM   #12503
BCbud's Avatar
This is the first time I have run this car on carpet. I ran it on asphalt last outdoor season. This is also the first run with this component layout and aluminum front c-hubs and rear aluminum bearing carriers.
Recycled teenager.
Old 01-10-2011, 07:54 PM   #12504
very interesting ... wow... definitely will give it a try especially if it will reduce the effect of dirt sticking to the tyres...
Old 01-10-2011, 08:03 PM   #12505
BCbud's Avatar
No, it will not help with dirt sticking to the tires, it will make the rubber soft and sticky. When our club runs outdoors, we clean the track with a large gas leaf blower and then spray the track with sugar water. The sugar water helps keep the dust down and is sticky to add traction.
Recycled teenager.
Old 01-10-2011, 08:23 PM   #12506
Oh... understood... Our track is actually prepped in the same fashion too... hmmm... I'm going to try and and find a good bottle of 'stuff' and hopefully get my hand on a tyre warmer soon...
Old 01-10-2011, 09:48 PM   #12507
alcyon's Avatar
your car is a little front heavy now right? i gotta try the moving the shock outward thingy, as far as i know it adds initial response but reduces some grip in the middle and exit of the corner.
alcyon is offline   Reply With Quote
Old 01-10-2011, 09:55 PM   #12508
BCbud's Avatar
The front of my car is about 8 grams heavyer than the rear. I moved the shocks out one hole to try and remove a bit of grip in the front. I think tightening the diff had more efect.
Recycled teenager.
Old 01-10-2011, 09:57 PM   #12509
alcyon's Avatar
tried softer rear springs yet? i tried it and really makes a difference, even though shocks are kinda straight. the rear end really sticks.
Old 01-10-2011, 10:02 PM   #12510
BCbud's Avatar
After my adjustments, I had so mutch traction that I would traction roll in the corners. The yellow springs I have in the back are the softest ones I have, 14lb. I may have gone a little too far so now I will try to fine tune it.
Recycled teenager.
