Xray T1
#8282
thanks man
#8283
Originally posted by dr_hfuhuhurr
So what's the status of parts for the XRay? Serpent doesn't carry them. Where can you get the new stuff? I'd like to pick up the ackerman extensions and the new rear camber link mount thingies.
Blake
Blake
Thanks for the support
#8285
Motor-Rear Belt Question?
I have a X-Ray T1 Evo 2 and I was wondering if it is okay if the rear belt slightly touches the motor? The front belt is okay. It is aproximately 4mm away from the motor. But, the rear is a different story. Any suggestions?
Thanks.
Thanks.
#8286
Will Xray and Hudy be available threw Horizon Hobby and or Great Pains, err Planes?
#8287
Hey-are they looking for any team drivers....Oh-wait-youve first got to be good to get sponsored.....??? Darn-counts me out..
Ray
p.s. I need your e-mail to forward your message onto Jimmy about the Halloween Classic.
Ray
Originally posted by Andrew Ellis
The new importer is Ralph Burch JR.. The company names are RC America,Hudy USA,Xray USA .. Everything will be allright way better then before and it should be allgood in a one to three weeks. The website will be up an running in a week or so it is www.rcamerica.com
#8288
question on Fk
Hey guys think you maybe able to help me out, i just got my Fk in the mail today and put it together. While i was doing i noticed after getting the whole rear and front parts in the Top deck was kinda hard to get on. Has anyone had this problem? I really had to push on the end of the top deck for it to finally get on.
And any suggestion on Stock racing setups.
Jon
Jon
#8289
I need some help. I have an Xray T1R that I am going to use in dirt oval. This is a new class we are trying to get going using late model bodies. We are running 19t motors and I picked up an Orion Element. I have the stock spur gear (92 teeth if I remember correctly) and will be running foam tires that are 60mm. What gearing should I start with? I am unsure how to gear a touring car for ovals so any help is appreciated. Also any suggestion on shock oil and springs?
Thanks!
Thanks!
#8290
Thanks.
Thanks.
i didnt like the stock set-up so i went on to look for more setups and i found a great baseline set-up at cefx.net.
as far as the upperdeck is concerned i noticed that you had to use slight force to pop in the upper deck. its ok as long as you dont tweek the chassis. place your chassis on a flat surface to see if any tweeking has occured.
#8291
Team EAM
Has anyone had a problem with the rear of the car being stiffer than the front? Mine is...I can go two steps heavier on the front springs and a sway bar on the front but the rear is still stiffer. Ive put new arms, hubs, tie rods, axles, shocktower, shocks, springs, etc. Ive rebuilt the car 3 times and still cant figure out why its like that?!?! Any suggestions?
EA
EA
#8292
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
EA
Is this on a FK
jdxray
I found that using the kit setup was already good,we do a lot of stock(27t) in the uk & first time out at my local track i was 5 secs of the track record set by a decent nat driver,& that was with mistakes caused by some glitching
Sorted the glitching out now
Is this on a FK
jdxray
#8293
EA
EA
Watch closely, lower mounting point (where the set screwed in)of shock assy.
In the back is wider than in front, with same damping there is no way you could get equal "stiffness"
There is only 1 car using exactly the same geometry front to rear, that is TC3.
#8294
Re: question on Fk
Jon
Jon
About how to eliminate the tweak when top deck is mounted.
#8295
