Xray T1
#8266
Re: shock length T1FK
Originally posted by markp27
There is no mention of this in the manual....I'm sure someone has posted it already, but I can't seem to find it in the postings.
Can anyone tell me what the correct length of the shocks is for the T1FK?
Thanks, Mark.
Thanks, Mark.
#8267
Does anyone know what the statis of parts is in the USA? As Serpent USA is no longer the import for Xray/Hudy products in the USA. Who and When available?
#8268
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
Rear roll centre
Which hole is favoured by the `i know how to setup cars` guys & girls if any
At the mo i`m using the top holes fore & arft
Am i right in thinking `if i use the top holes i get less grip` cause i have raised the roll centre closer to COG
#8269
Re: Rear roll centre
But, you are effectively correct - the lower the position, the more grip you would get, as the shocks are a little softer due to the angle.
Think more about changing the spring hardness and oil before moving the position of the shocks on the tower.
But certainly roll centre and anti-roll bar settings should be your first settings to play with (assuming your tyre and insert choice is correct).
Hope this helps a little.
#8270
mark
Thanks, just curious really,
The car is nearly there for me (cs-tyres on asphalt),
Next Q)
What colour springs are the most popular?
Next Q)
#8271
mark
Next Q)
mark
Next Q)
Cheers, Mark.
#8272
i know this kinda off subject but was wondering what is the latest starting setup for ashphalt ? what springs, shock oil, etc ?
#8273
also for got im using the spec tire for the norrca nationals, which i have no idea what it is
#8274
-Korey
#8275
myTSN has numerous asphalt setups.
#8278
Originally posted by S-T-R-l-K-E-R
i also got the 4 hole shock tower i also have those questions in mind. i think the 4 hole shock tower is for carpet use. i run my can on asphalt and it seems to work fine. honestlyi think my t1fk hs the best handling over the other xrays around (locally).
* all other fk's in my area have the 3 hole shock tower.
#8279
thanks for the responce, but i was wondering if anyone knew what the spec tires for the norrca nationals?
#8280
I think Take Off CS27's are the tire for the Nats.
