Xray T1
#7876
Hey, I have a quick question for anyone who can answer to confirm this. I have the T1R, and am getting the Spring Steel Hubs. I just need to know if these two part numbers are the ones I need:
305315
-and-
305215
Thanks in advance,
Kevin
305315
-and-
305215
Thanks in advance,
Kevin
#7877
lets this call them ?. i can't remember what they are called too. I did notice that i replace two b/f w/ serpent ones and it is driving me crazy. I will buy some new ones at the track tomorrow.
thanks for the suggestion
#7878
wap
the size of the tire will affect ride hight and you may need to purchase the carpet shock towers to get the ride hight down. I see that you are in fort worth. If you are running at Mike's on saturday, let me know and we can work on it
#7879
305315
-and-
305215
Thanks in advance,
Kevin
305315
-and-
305215
Thanks in advance,
Kevin
Just need a set for the front. The rear doesn't need them and you can save the rotating mass by using the stock ones.
On a similar note, anyone with a FK who's has a set of the FK outdrives for sale, I'd like to get a set.
Blake
#7880
Thanks blake. Are the 305215's for the rear though? Or are they the same all around?
Thanks,
Kevin
Thanks,
Kevin
#7882
Oh ok. Thanks again. I was just wondering.
-Kevin
-Kevin
#7883
Originally posted by Wap
also kaizen, is that 62.5 mm from the center of the hole or from the very top of the shock to the very bottom. thanks
#7884
Base carpet setup
Hi All,
Just converted my Evo 2 from Pivot Ball to C-hub. I'm running foams on a medium grip carpet. The car has been very quick but i feel i might be able to carry a bit more speed with the c-hub setup and was wondering what a good base setup would be. Also running the roll center bridge. At the moment i just set it up as per the setup sheet but i think this is a rubber tire setup.
#7886
how many holes does a carpet shock tower have?
#7888
oh thanks !!! cause i noticed that one of the guys has an FK too and his shock tower only has 3 holes and mine has 4. just wondered whats up with this.
#7889
does anyine know if there was a problem with the shocks on the FOC, i herd the bottom plastic were coming off and this has happend to mine. it has something about the O-rings.
what do u need to do to fix it.
#7890
That happened to me once, but I didn't turn it all the way on. You need to just make sure it is all the way on there. I haven't had a problem since.
-Kevin
-Kevin
