Xray T1
#7891
i have checked and when i still pump the shock it starts coming loose.
is there a easy fix?
#7893
I don't know anything about the xray's other than there a great looking car and I'm thinking of getting one. I was wondering if the T1R and the EVO 2 can be upgraded to the Factory Kit and if so what's to upgrade or is the factory kit a completely different car all together.
#7894
the factory is basically the same as the evo2 or tir. But it does cost quite a bit for the upgrade. you will need to purchase bulkheads, short arms. hinge pin retainers, rear shock tower, captured rod ends. and if you really want factory lighted diffs and lighted hex drives. you are looking at well into the $200 to make it factory. And I know there are places that are sellign the factory for $289 or so
#7895
And..... Front shock tower, lightened driveshafts, low ratio pulley kit, alloy layshaft and stiff topdeck.
You'd be better off getting a new factory kit.
#7897
yes to achieve some gear ratios belt rubbing is nessesary. although it WILL NOT cause any bind on the drivetrain. because under acceleration your belt lifts and doesnt hit the motor.
#7899
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
Right here goes
Just had my first run with the FT kit
Brilliant very nice indeedy apart from!!!
castor blocks on wrong way round?
screw was`nt done up on rear bulkhead holding the wish bone on(it all fell off)
took the oneway out put in diff as it felt like it was to close to the edge
very nice just as fast as my Aeast yoko sd if not faster round the corners(running 27t)
scratch my blasted chassis
#7901
Who's got the factory kit for $289?????? Cheapest I saw was Speedtech for $312
#7902
Registered User
#7905
Registered User
order hubs and arms.
