Old 07-09-2004, 08:33 PM   #7876
etzkev's Avatar
Send a message via AIM to etzkev
Hey, I have a quick question for anyone who can answer to confirm this. I have the T1R, and am getting the Spring Steel Hubs. I just need to know if these two part numbers are the ones I need:
305315
-and-
305215
Thanks in advance,
Kevin
etzkev is offline   Reply With Quote
Old 07-09-2004, 08:34 PM   #7877
Wap
lets this call them ?. i can't remember what they are called too. I did notice that i replace two b/f w/ serpent ones and it is driving me crazy. I will buy some new ones at the track tomorrow.
thanks for the suggestion
Wap is offline   Reply With Quote
Old 07-09-2004, 09:46 PM   #7878
theisgroup's Avatar
wap
the size of the tire will affect ride hight and you may need to purchase the carpet shock towers to get the ride hight down. I see that you are in fort worth. If you are running at Mike's on saturday, let me know and we can work on it
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 07-09-2004, 09:50 PM   #7879
dr_hfuhuhurr's Avatar
Trader Rating: 75 (100%+)
305315
-and-
305215
Thanks in advance,
Kevin
You need #305315.
Just need a set for the front. The rear doesn't need them and you can save the rotating mass by using the stock ones.
On a similar note, anyone with a FK who's has a set of the FK outdrives for sale, I'd like to get a set.
Blake
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 07-09-2004, 09:52 PM   #7880
etzkev's Avatar
Thanks blake. Are the 305215's for the rear though? Or are they the same all around?
Thanks,
Kevin
Old 07-09-2004, 09:53 PM   #7881
You said you're running a T1R...they are the same all around.
Blake
Old 07-09-2004, 09:54 PM   #7882
etzkev's Avatar
Oh ok. Thanks again. I was just wondering.
-Kevin
Old 07-09-2004, 11:18 PM   #7883
kaizen's Avatar
Originally posted by Wap
also kaizen, is that 62.5 mm from the center of the hole or from the very top of the shock to the very bottom. thanks
it was tip to tip...but, again, you might want to verify the length.
kaizen is offline   Reply With Quote
Old 07-10-2004, 08:07 PM   #7884
B4
B4's Avatar
Default Base carpet setup
Hi All,
Just converted my Evo 2 from Pivot Ball to C-hub. I'm running foams on a medium grip carpet. The car has been very quick but i feel i might be able to carry a bit more speed with the c-hub setup and was wondering what a good base setup would be. Also running the roll center bridge. At the moment i just set it up as per the setup sheet but i think this is a rubber tire setup.
B4 is offline   Reply With Quote
Old 07-10-2004, 08:10 PM   #7885
NVisible's Avatar
Hey, im looking for a NIB evo2 FOC. Is there places still selling them or has the factory kit replaced them totally now?
NVisible is offline   Reply With Quote
Old 07-10-2004, 08:52 PM   #7886
S-T-R-l-K-E-R's Avatar
Send a message via ICQ to S-T-R-l-K-E-R
how many holes does a carpet shock tower have?
S-T-R-l-K-E-R is offline   Reply With Quote
Old 07-10-2004, 08:56 PM   #7887
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
4, but the tower itself is lower. You can then run the body lower
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 07-10-2004, 09:03 PM   #7888
oh thanks !!! cause i noticed that one of the guys has an FK too and his shock tower only has 3 holes and mine has 4. just wondered whats up with this.
Old 07-10-2004, 10:05 PM   #7889
Matt04's Avatar
does anyine know if there was a problem with the shocks on the FOC, i herd the bottom plastic were coming off and this has happend to mine. it has something about the O-rings.
what do u need to do to fix it.
Matt04 is offline   Reply With Quote
Old 07-10-2004, 10:08 PM   #7890
etzkev's Avatar
That happened to me once, but I didn't turn it all the way on. You need to just make sure it is all the way on there. I haven't had a problem since.
-Kevin
