Xray T1
#6031
general setup question
There are a bunch of us at my track that run xrays. My setup seems to be the stiffest with 40lbs front and 35(?) lb rear springs 50wt front with all holes closed and 40wt rear with 2 clicks on the shocks.
Other guys run essentially the stock setup, maybe a little stiffer. I didn't like it because the car really leaned into the corners and came close the traction rolling.
Is this a driving style thing or is there a benefit to running a softer setup with more angled and shorter camber links? When my car is working (not consistent, still learning TCs on carpet. 1st season in about 10 years...) I can turn within 2 laps of TQ and show in the A main.
pucho?
pucho?
#6032
Location: If Nissan Motorsport is Nismo, Then Honda Motorsport must be Homo
Originally posted by Pyramid
How can different (lower) internal ratio makes the shaft spins at the same rate/speed? I might be wrong.. thats why I ask
I think the reason behind the low internal ratio pulley set is just the exact same with one of the design purpose in Serpent S710 ( or it maybe the other way around, the design of T1 low internal..... that inspired the S710).
#6034
Originally posted by vadn1
Kennedy,
What pinion and gear set up do you have with the 5800ss? What run time you get the the 3300s and how does the 5800ss set up run against 19T motors. What are you motor and esc temps after a 5 min run?
Kennedy,
I run standard gearing on 48 pitch so about 90 Spur and 28 pinion
I also run a 5V fan if I take the gearing up to 30-32
#6035
servo
is a futaba 9451 over kill or not enough power for a T1R. Will it be tooo heavy, will it fit in the car, to slow of a servo?
The T1Rs will be for club racing only with a brushless systems.
One is for myself, some experiance racing with a 5800ss
one is for my wife, no racing experiance with a 4300ss
Both cars will be T1Rs'.
#6036
Re: servo
is a futaba 9451 over kill or not enough power for a T1R. Will it be tooo heavy, will it fit in the car. The T1Rs will be for club racing only with a brushless systems.
#6038
kennedy,
I have several from my nitro car. Putting the 1/8 scale away for the time so I can race electric with my wife. Thanks for the quick response, 9541 it will be.
kennedy,
#6040
Re: general setup question
pucho?
pucho?
My understanding is that you want the car to be as stiff as possible, yet still be able to handle bumps and have enough traction to carry good corner speed. Too stiff and you'll probably need to slow down to avoid loosing too much stability and/or your car won't handle bumps well. Too soft and the car will roll more putting more load on the tires--this can also cause the tires to break loose and make the car unstable, or do just the opposite and cause a traction roll. Again, you'll need to slow down in order to keep the car in check.
There's another part to this which is drivability. A softer car is usually easier to drive because it reacts slower. For many people this is a "faster" setup because it can help them run consistent lap times. A stiffer car is generally quicker, provided it's not too stiff for the surface, but it can be harder to drive because it reacts faster (commonly referred to as "twitchy"). This type of setup can make a driver "slow" because they're making too many mistakes--or they have to slow down too much to avoid making those mistakes. Someone who can drive what you might consider a "twitchy" car fast and consistent is usually a person you're trying to catch.
So you want you car to be setup such that it can be driven consistently (i.e. easy to drive for your skill level), yet still be quick. For some people this is a setup on the stiffer side and for others it's on the softer side. (I often see newer drivers find and stick with a "soft" setup because the car is handling well and is easy to drive, so they assume it's as fast as it's going to get...) Part of being a fast driver is being really smooth and limiting weight transfer. This gives you more traction than other drivers, given the same or similar tires, allowing you to run stiffer setups and thus be able to carry more corner speed...
It would be great to get some comments/corrections from Alex Lopez on this topic! Alex?
#6041
Being use 710 for about 3 gallon (almost 6-7hours) with no bearing maintenance.
#6042
Trader Rating: 22 (100%+)
Re: Re: Lazy out of the turns
Originally posted by Besercoe
Running outdoors asphalt foams on 26mm rims, i cant understand why anyone would want to run anything wider, i can only assume the extra grip generated by the carpet locks the car in as it is. especially in spec classes i would have thought that you would want to free up the car in the corners by going to a narrower and harder compound. I generally run 26 mm foam, and adjust the shore rating to suit my needs, anything from 35 to 42, in both front and rear compositions.
In Stock and 19t i have cut the tire down to 24 mm with good results.
#6044
wow, fromt eh factory kits of xray they are testing new chassis At 3.5 mm thick and 4.0 mm thick Don't know if they already posted this. If They did Sorry.
#6045
ultra stiff chassis, the less chassis twist the better
