Xray T1
#6181
Re: Foam tire size ?
Originally posted by XRaycer
I'm just kind of curious how small can you run your tires, until it begins to adversely effect handling? Thanks in advance
First-if its the new Jaco-rims-which are a larger diameter-you can only get down to about 2.199". Any smaller and your running on felt covered plastic.
Second-the level of grip available in the racing surface. If its low grip, larger tires will provide more side bite and smaller tires might just slide.
And last-sometimes smallish 2.19" to 2.22" are the hot ticket.
#6182
I ordered the arms off of the Xrays web site. The order comes directly from Serpent. When I called them last week they said that they had just received a large shipment of them, so they should be pretty easy to get now. As far as installation goes, you pretty much just move the hinge pin mounts from the inside of the bulkheads to the outside.
#6183
Re: Re: Foam tire size ?
Originally posted by rayhuang
It really depends on a few things.
#6185
Re: Short arms
Originally posted by Ralf
Hi Guys,
What parts do I need to buy in order to install the short arms ?
thanks for your input
Hi Guys,
I think they come in pairs and you need four of them, two front, two rear.
Just need to steal the droop screws from your long arms as well.
#6186
Guys, I just finished adding my servo to my T1R, but seem to be having trouble with the drivetrain now. I have Jaco Foams on and they have not been trued down in the front (28mm). I adjusted the trim so that they don't rub the shock cups in the front, but I had to turn the epa even farther down so that the axles didn't grind. Now I have a rather large turning radius and don't think it will work for racing. Any ideas?
#6187
Thanks for the help sounds like I'm in the right ballpark.
#6188
#6189
Re: Re: Short arms
Thank you sands
Originally posted by sands
XRA302032 - it's the aluminum nut that is used to hold the little plastic shaft pivot to the bulkhead. Or you can cut the one in the front and back in half....
#6190
Does anyone have any input on running long Frt Arms & Short Rr Arms, like the losi xxx-s carpet setup?
#6191
@ Kickind Foam tires
What we did at the Snowbirds was just as you just wrote. Put on as much steering as you can, but the tire schould not tuch the Shock cup mounted at the A arm. If you made this right you will have no problem with steering. That schould be all.
Regards
Andreas
Regards
Andreas
#6192
Long front A arms, Short rear A arms
I did try this but it was not better in any configuration. I would suggest that you use the short A arms both front and rear, and after that work on your setup. That schould do it for you.
If you have any other questions about the car, just ask.
/Andreas
/Andreas
#6193
Besides more steering, what exactly is the advantage to running short arms?
#6194
It changes the roll center of the car to reduce the roll tendancy. This lets you run softer springs, but not traction roll. the car will react faster to inputs, have more grip, and more corner speed.
that's the theory anyway. All (most?) of the factory and top xray drivers are going to them.
#6195
Andreas, you got PM.
