Xray T1
#5596
Regional Moderator
Originally posted by JCB
Hey there,
Which stiff upper plate are you speaking of? Do you have a part# for this plate? I would like to check it out.
thanks in advance,
Hey there,
thanks in advance,
the Xray part # is 301161 Upper Deck 2.5mm Graphite. Here is a pic of the stiff top plate:
#5597
Hey PorscheSuperCup,
Thanks man! I will look into buying this. Will it benefit me for carpet racing?
One more thing, Local hobby shop doesn't have any XRAY Parts. Any good places I can them at? I need 6 degree caster blocks. Also what's the 1.77 gears i'm hearing about in this forum?
THANKS!
THANKS!
#5598
Jcb-I used the solid top deck.
Alex Lopez
Alex Lopez
#5599
Alex Lopez
Alex Lopez
Thanks, Looking to get one? Know of any hobby shops who has them in stock?
#5600
Anyone else have this problem
I have been having a problem with the Xray (with c-hub suspension). I have had a number of the drive shafts pinch down on the sleeve (coupler) that pivots inside the springsteel hub. When this happens it seriously reduces the ability of the dogbone/driveshaft to swivel in the hub which in turn causes the car to seriously slow down. The best way to see if you are having this problem is to take apart the front end and pull out the entire drive shaft/coupler/and hub...then check the rotation that you have. In order to check it wihtout tearing it apart, turn the wheel all the way in one direction and then start spinning the wheel by hand.....you will feel it bind up. What I was wondering is if anyone else has had this problem and what did they do to fix. I think it may be caused by too much throw in the steering and then it twists from the loads caused in a wreck.
I am not the best driver in the world but I am A or B main in our local club and I rarely do not finish heats with the X-ray or the TC3 when I ran it. I am pretty consistant so I am not out there tearing this thing apart. It has become very frustrating...so much so I ran the TC3 this past weekend ( I hate that car compared to the XRay so I need a fix!!!). Not to mention, I am having a hard time finding the 305320 (drive shafts)
I have also tried to limit the throw by putting a ball stud on the bottom of the steering knuckle...this hits the arm and limits the throw...still to much maybe!
#5601
Originally posted by froghead
Yea, the end of the motor touches the chassis which doesnt allow the motor to rotate down enough to get proper gear meshing. It's to tight with the pinion/spur gear.
#5602
joneser,
possibly reduce the steering end point of your transmitter? I have my m8 set at 75% and still have way too much. I even put a front anti-roll to reduce the front turn-in some more.
#5603
Re: Anyone else have this problem
I think that you were experiencing the same thing.
If reducing the steering angle ruins your setup. then reset-up the car to handle having less angle.
#5604
Reducing the steering angle is a solution and if there is any slop with the c-hub and arm simply use teflon motor shims to reduce/remove it. If there is any slop with the ball cups and studs use plumbing teflon tape to clean up the play.
#5605
Just placed an order for some stuff through ashford hobby (www.ashfordhobby.com). They had EVERYTHING I wanted in stock. Serpent didn't have half the stuff. If you're looking for XRay parts...ashford is awesome!
#5606
#5607
Pucho, big thanks on stocking those. I was couldn't believe a bearing went out that quick. The layshaft really doesn't have support other than the bearings to hold it in place and the spur side is rather thin, so that's gotta be what gives out! Thanks again! The plastic piece comes in the bag with the tensioner pieces for the outdrive bearings.
#5608
Ashford Hobby
Yes, Robert at Ashford is awesome to deal with. Keeps a good inventory and is knows what he is doing. He is a great resource for serpent too!!!
#5609
Registered User
hey guys i dont have the 1.77 gears yet so i was wondering for stock what spur are u using with the standard gears thanks
jesse
jesse
