Like Tree3Likes
Xray T1
Old 09-30-2003, 09:47 PM
  #4846
Carbon_Fibre3's Avatar
i feel the need to profess to u all how stupid i am..
rebuilding my car atm only to realise that.. i had chubs on rong way roung... thus giving negative caster.. eeek.. that explains most of my handling woes..
oh well.. live n learn ey!
Rob STorey
Carbon_Fibre3 is offline
Old 10-01-2003, 10:03 AM
  #4847
CRASH's Avatar
Trader Rating: 26 (100%+)
Post mike_Webb
With foam tires of that size you need to use the stock front shock tower to get the proper ride height. I had the same problem as you are describing.
Later,
CRASH is offline
Old 10-02-2003, 02:39 AM
  #4848
Trader Rating: 90 (100%+)
mike_webb,
Easy fix is to use the TC3 shock coupler. Allows the spring to site lower. Serpent or X-Ray also makes an aluminum set that lower the springs too, but easiest and cheapest is to use the AE spring retainer dealio's........
Hope this helps.
RBLove is offline
Old 10-02-2003, 02:49 AM
  #4849
David Galdo's Avatar
Trader Rating: 15 (100%+)
I don't recall the part number but I have a set of Tamiya spring retainers that were really cheap.
David Galdo is offline
Old 10-02-2003, 05:47 AM
  #4850
XRaycer's Avatar
RBLove thanks for your setup I'll give it a try and let you know how it worked for me
XRaycer is offline
Old 10-02-2003, 06:01 AM
  #4851
CRASH's Avatar
Default mike_Webb
The Shock Tower for Foam Tires is for Pivot Ball. The Stock Shock Tower is for C-Hubs. When it comes to running smaller foam tires that is.
My experience that is.
As for setup it is:
1.77 Pulley Set
Med Front A-Arm
3 Degree Carrier
Xray 30Weight Oil, 2 Holes Open, Dark Blue Springs
#2 Hole on A-Arm and #2 Hole on the Shock Tower
Camber is #1 Hole on Shock Tower and #2 Hole on Hub Carrier
One-Way Diff
-1.5 Degree of Camber
0 Toe-In
2 Droop
Medium Rear A-Arm
Xray 30Weight Oil, 3 Holes Open, Blue Springs
#2 Hole on A-Arm and #7 Hole on the Shock Tower
Camber is #2 Hole on Roll Center Bridge and #2 Hole on Hub Carrier
Diff Tight
2 Degrees Toe-In
6 Droop
Plaids Front
Purples Rear
Start with tires at 63mm
28/128 Reedy KR 10x2
Hope this helps,
Later,
CRASH is offline
  #4852
John Fontaine's Avatar
Question for you guys.
I decided to buy alum C-hubs for the front, just the 3º C in alum, not the knuckle (composit is too brittle). Well when I went to put it together with the alum blocks I noticed that the C-hub bushings were a lot bigger than the composits and that the knuckle floated up/down too much. What I came up was putting the composit C-hub bushing (xray 302290) inside the alum c-hub bushing (double bushing!) and than the 3 mm hex screw (M3x12) into the knuckle. This works good, no slop and pivots well. Is this how it's suppost to be done. Is the alum knuckle different specs than the composit? The alum c-hub bushings look like they fit a 4mm screw if you don't use the composit C-hub bushing inside it. Confusing I know...maybe someone else has gone through this as well.
John Fontaine is offline
Old 10-02-2003, 07:38 AM
  #4853
Post Re: mike_Webb
I had the same problem, switched shock towers no more problem.
As for setup it is:
1.77 Pulley Set
Med Front A-Arm
3 Degree Carrier
One-Way Diff
0 Toe-In
2 Droop
Medium Rear A-Arm
Diff Tight
2 Degrees Toe-In
6 Droop
Plaids Front
Purples Rear
Hope this helps,
Later,
I've tried your mentioned gears (128/28) running a 10x2 motor, it ends up with burn out of the brushes, any suggestions? Also I tried the layout of the front suspension and find out the spring not touching the collar, is that normal? Thx!
octavone2003 is offline
Old 10-02-2003, 07:48 AM
  #4854
as Xray has a few stiffness on the c-hub A-arms...does anyone know which does it comes with the Aluminium Chub F+R set...i know my T1R came with medium front and soft rears and it seems that the aluminum chub conversion came with Med front/Hard ears..does anyone knows?
thanks
fReShJiVe is offline
Old 10-02-2003, 07:50 AM
  #4855
CRASH's Avatar
Default octavone2003
With my motor geared at 28/128 it does get a little warm. But it does not damage the brushes any. I get about 2-3 runs out of it before a rebuild. Our track is a 180x 80 if that helps. Also what brushes are you using? I am using Lightspeed brushes.
The springs should not touch the collars when setting on a stand. There should be a gap between the spring and the collar.
Later,
CRASH is offline
Old 10-02-2003, 08:23 AM
  #4856
CRASH's Avatar
thanks
The A-Arms are medium.
Later,
CRASH is offline
Old 10-02-2003, 10:54 AM
  #4857
Neil Rabara's Avatar
I'll be at the Hobby Vision Show in Las Vegas. I'll take a hard look at the new Xray cars and report my findings. I'll take a pic or two also.
Neil Rabara is offline
Old 10-02-2003, 11:00 AM
  #4858
Later,
thanks crash....just got some parts number from my friend and it seem that it is soft front/medium rear
Old 10-02-2003, 03:47 PM
  #4859
mike_Webb's Avatar
Crash.
Here is what I have...
http://www.mytsn.com/products/imggal.asp?prid=2586
It is made for the C-Hub stuff.
mike_Webb is offline
Old 10-02-2003, 07:24 PM
  #4860
alana07's Avatar
Trader Rating: 53 (100%+)
thanks
i gotten the alu c hub set when they were initially released, the front arms were soft and rear arms medium.
alana07 is offline
