Xray T1
#4471
Originally posted by mike_Webb
Freshjive...
Be aware that the X-Ray springs that you correspond to the Serpent Springs are longer then the serpent springs. So if you use the serpent springs you may have a hard time making ride height.
Freshjive...
I decided not to use my serpent spring and get a few more Xray spring to play around with setups...easier to share setups IMO
#4472
Shock Tower?
Hey guys.....anyone have a spare graphite shock tower (front) that they would like to sell. I am not looking for the ultra low tower but the standard carpet shock tower will do. Let me know and I can paypal immediately. Thanks.
#4473
I checked my stash and do not have any Carpet ones. I have 2 Original T1 Rear Towers and 1 Original T1 Front Shock Tower if anyone wants to buy them.
#4474
Re: Shock Tower?
YGPM
Jim
#4476
I am pretty sure you don't need the Solid Pully
#4477
im pretty sure u can use the layshaft from teh evo2 as it has holes drilled already... but not positive.
#4478
yes, you can use the original evo2 center layshaft. just lock the pulleys with small pin (the ones that you use in the body post). there are two holes in the center layshaft.
put two 3x6mm bearings between the front pulley and right bulkhead so the washer that hold the pulley won't come lose during acceleration or you can use anything that fits and holds the front pulley washer from coming loose. kinda hard to explain, but you got the idea.
#4480
you da man !
#4481
Originally posted by Ralf
Hi Guys,
I recently bought a second hand Evo2 and would like to use the new 1.77 ratio pulley,
Do I have to buy also the solid axle layshaft or I can use the EVO2 layshaft and block the central oneway.
Thank you for your help,
Raphael
Hi Guys,
Raphael
#4483
Foam Carpet... Purple and Violet
