Old 08-25-2003, 06:40 PM   #4471
Originally posted by mike_Webb
Freshjive...
Be aware that the X-Ray springs that you correspond to the Serpent Springs are longer then the serpent springs. So if you use the serpent springs you may have a hard time making ride height.
Thanks mate,
I decided not to use my serpent spring and get a few more Xray spring to play around with setups...easier to share setups IMO
fReShJiVe is offline   Reply With Quote
Old 08-25-2003, 07:23 PM   #4472
Default Shock Tower?
Hey guys.....anyone have a spare graphite shock tower (front) that they would like to sell. I am not looking for the ultra low tower but the standard carpet shock tower will do. Let me know and I can paypal immediately. Thanks.
Joneser is offline   Reply With Quote
Old 08-25-2003, 08:02 PM   #4473
mike_Webb's Avatar
Send a message via AIM to mike_Webb
I checked my stash and do not have any Carpet ones. I have 2 Original T1 Rear Towers and 1 Original T1 Front Shock Tower if anyone wants to buy them.
mike_Webb is offline   Reply With Quote
Old 08-25-2003, 08:48 PM   #4474
Jimmy Fukuyama's Avatar
Default Re: Shock Tower?
YGPM
Jim
Jimmy Fukuyama is offline   Reply With Quote
Old 08-26-2003, 04:41 AM   #4475
Hi Guys,
I recently bought a second hand Evo2 and would like to use the new 1.77 ratio pulley,
Do I have to buy also the solid axle layshaft or I can use the EVO2 layshaft and block the central oneway.
Thank you for your help,
Raphael
Ralf is offline   Reply With Quote
Old 08-26-2003, 06:56 AM   #4476
mike_Webb's Avatar
I am pretty sure you don't need the Solid Pully
Old 08-26-2003, 07:04 AM   #4477
Carbon_Fibre3's Avatar
im pretty sure u can use the layshaft from teh evo2 as it has holes drilled already... but not positive.
Carbon_Fibre3 is offline   Reply With Quote
Old 08-26-2003, 07:45 AM   #4478
redsand's Avatar
Send a message via Yahoo to redsand
yes, you can use the original evo2 center layshaft. just lock the pulleys with small pin (the ones that you use in the body post). there are two holes in the center layshaft.
put two 3x6mm bearings between the front pulley and right bulkhead so the washer that hold the pulley won't come lose during acceleration or you can use anything that fits and holds the front pulley washer from coming loose. kinda hard to explain, but you got the idea.
redsand is offline   Reply With Quote
Old 08-26-2003, 07:58 AM   #4479
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
Just lock it down in place one way or another so to speak.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 08-26-2003, 08:03 AM   #4480
redsand's Avatar
you da man !
Old 08-26-2003, 08:33 AM   #4481
Neil Rabara's Avatar
Originally posted by Ralf
Hi Guys,
Raphael
You can use the layshaft that came with the car. Just replace the stock pulleys with the new ones. Just make sure that you lock the central layshaft by tightening the nut all the way down so the one way does not spin.
Neil Rabara is offline   Reply With Quote
Old 08-26-2003, 12:10 PM   #4482
Scrad's Avatar
Trader Rating: 15 (100%+)
What spring colors are you guys normally running for the Evo2 on carpet? Rubber and foam's. Thanks.
Scrad is offline   Reply With Quote
Old 08-26-2003, 12:14 PM   #4483
mike_Webb's Avatar
Foam Carpet... Purple and Violet
Old 08-26-2003, 01:06 PM   #4484
Moderator
rubbers i run whites, hey scrad, do i know u????
SMC Racing
Old 08-26-2003, 07:35 PM   #4485
Scrad's Avatar
I usually run in Oshkosh and occasionally at Road Rage.
