Xray T1
#3976
Originally posted by RedBullFiXX
Heay Neilio:
Did you know that Swanson prefers the T1R chassis to the evoII, even though he races mod at SoCal .... read... very high bite track
Heay Neilio:
yea I know, I honestly like the T1R at Socal also. But, it's difficult to tell which chassis is better because the traction is high on the asphalt. The T1R will grip a bit more, but that fine line is hard to find.
#3978
Originally posted by RCInfinity
There are some cases where the T1R chassis is better, but the majority of the time the Evo2 chassis is widely used. Due to the high flex of the T1R chassis, its best use is in a cool or cold temperature with low grip. In a high temp and/or high grip situation, the Evo2 chassis is better. When the heat is there, I do not recommend using the T1R chassis because it is plastic and can warp due to heat. Even heat from the batteries.
#3979
flex
pucho do you realy know the difference between chassis flex or driver brain flex
#3980
Well you Know how I am, Im good for 2/12 minutes them it all goes down hill from there.
#3981
Hey guys, does anyone have any links to actual setups for TQ Hobbies or the Coral Springs track? I really don't want to spend 3+ hours going through the 100+ pages of this thread searching for it, lol.
#3982
t1r setup
Front:
Spring/ Blue
Oil/ Xray 30wt
Piston/ fixed 3 hole
shock possition standard on tower and arm
camber link position standard
0 Kick up
3* Caster block
1* camber
0 tow
4.5mm RH
spool(faster with one-way, but More consistent with the spool)
Rear:
Spring/ blue
Oil/ Xray 30wt
Shock position standard on tower and arm
camber link on lower inner hole on bridge/standard on block
3*antisquat
1.5* camber
3* tow-in
5mm RH
Diff fairly loose
Misc:
Body/ Losi Alfa
Tires/ Pre mounted TO CS-27's
Monster stock
3300
gearing 128/32 FD+7.008 (with new pullys 1.77IR)
weight was 52.4 had to add one or the long center chassi weight's to make weight
Spring/ Blue
Oil/ Xray 30wt
0 Kick up
3* Caster block
1* camber
0 tow
4.5mm RH
Rear:
Spring/ blue
Oil/ Xray 30wt
3*antisquat
1.5* camber
3* tow-in
5mm RH
Diff fairly loose
Misc:
Body/ Losi Alfa
Monster stock
3300
#3983
Racenut, what track is that for?
#3985
Here is my set up For superior:
Front:
Spring/ Blue
Oil/ Xray 30wt
0 Kick up
3* Caster block
1* camber
0 tow
4.5mm RH
Rear:
Spring/ blue
Oil/ Xray 30wt
3*antisquat
1.5* camber
3* tow-in
5mm RH
Diff fairly loose
Misc:
Body/ Losi Alfa
Monster stock
3300
And TQ:
Front:
Blue springs
30Wt oil
3 hole fixed piston/2 hole if you use adjustable
standard shock mounting position
standard camber link position
0deg kick up
3deg caster block/6 deg if you need more on power steering
1deg camber
0deg tow
4.5mm ride heith
one way
Rear:
Blue springs
30wt oil
camber link on inner bottom hole on bridge/inner hole on hub
0 anti squat
2deg tow
1.5deg camber
5mm ride heith
diff set loose
Geared with a monster stock at about 7.80 (short track)
proto status 2.0
Front:
Spring/ Blue
Oil/ Xray 30wt
0 Kick up
3* Caster block
1* camber
0 tow
4.5mm RH
Rear:
Spring/ blue
Oil/ Xray 30wt
3*antisquat
1.5* camber
3* tow-in
5mm RH
Diff fairly loose
Misc:
Body/ Losi Alfa
Monster stock
3300
And TQ:
Front:
Blue springs
30Wt oil
0deg kick up
1deg camber
0deg tow
4.5mm ride heith
one way
Rear:
Blue springs
30wt oil
0 anti squat
2deg tow
1.5deg camber
5mm ride heith
diff set loose
proto status 2.0
#3986
Regional Moderator
hey pucho,
I noticed that both you and racenut have geared a monster stock at 128/32 for a final of 7.08 with the new pulleys. I run on a track that is 130 ft long by 65 ft wide. What size track do you have your motor geared this way, I race tomorrow and havent tried my new pulleys yet.
#3987
That was for Superior hobbies that about 120X60. It was a pretty wide open track (gas cars run there too) with a long straight.
#3988
Originally posted by xxxkat
I race at Showtime in Bakersfield(100 + in the summer)So i'm thinking i should get the evo II chassis.The track is med to hi traction with track temp's of 120 + so it could warp the t1r chassis,I know thats a problem with the tc-3's,thanks for the replies.
#3989
t1r chassis
I have raced the t1r in constant 145 tracktemps with no problems with tweek yet.I may buy a evo 2 chassis plate to try it but at this point the tweeking issue is nill for me.If the outside ambient temp is 100 degrees I usually stick my car on a fan I use for cooling my batteries after discharge.Works wonders.Just my opinion and observation.
#3990
Originally posted by PorscheSuperCup
i just got done putting the 1.77 pulleys and the 3mm rear belt on my car. What a difference this has made in the car. the drivetrain has less friction with the new belt and pulleys. I cant wait to get it out on the track this sunday.
How did you do with the new pulleys and rear belt?
