Xray T1
#3826
The aluminums are nice, but they wear out fast. The steels are better, but they are heavier. I personally like titanium.
#3827
#3829
I have been ussing a set of robinson aluminum pinions for ove 3 years now with out problem or niticeble wear. My buddy Alex has a full set of the Xray aluminum ones and they are nice. Im sure the steel ones are longer lasting but heavier.
#3830
Any of you guys had troubles trying to install two or more caps with the speedo on the T1R?
#3831
I use one large cap mounted on top of my speedo(GMV12)
#3832
Rubberneck~racing bumpers
Here is a pix of one of the first (thicker) bumpers, note I had to notch for the bumper brace, since then I have found a thickness that will eliminate the need to notch...
This pic is of the bumper only...
#3833
wannabee: did you get the pmt for my bumper?
#3834
Pucho, yes I did and your bumper is logged in for UPS and should go out tomorrow, so with alittle luck you'll have it B4 the weekend...Here is the mounted bumper...Forgot to mention that these bumpers are 10mm wider on each side to help protect the wheels...
PS: Nice ride Pucho!
#3835
Pucho, the setup you posted for TQ, is that for a T1R or an Evo2? Nearly all of my touring car experience has been on carpet, so i'm really clueless as to what to do for an asphalt track like TQ.
#3836
23000 uf capacitor install.
#3837
wannabee: Thanks Im looking forward to it. Thanks on the compliments.
Accord: Yes it's for the T1R but Alex runs a similar set up on the EVO2 at Corral Springs
racenut123: I personally run a 4700uf cap and it seams like it's good enoth I don't know where I could fit a larger one. But you know what they say bigger is beter!
#3838
#3839
Yes, because the first time I ran the car was at corral springs, them at MDI and then at TQ. I needed a lot of work at MDI but we only went there because we got rained out.
