Xray T1
#3496
NEW PULLEY'S???
Since the pulley's are a different size what will the internal gear ratio change too??? Currently is 2.125
#3499
I heard 1.88 closer t the Losi and Corally.
#3500
o.k. Decided that a rebuild was in order this week and I figured out a few cool things as you may know I have both cars. So I built a hybrid of the two.
I figured out that you can convert the top shaft of the evo 2 to a solid shaft removing the one way bearing and replacing it with the pullies from my T1R.
Guess I should have figured that out long ago. the Evo 2 top shaft has holes in it already to do so.
This makes me very happy as I have a ton of Trinity 64p spurs and could run them on the T1R top shaft cause of the mounting holes. problem solved
#3502
On my T1R I run them as loose as posible and I have not had any problems with skiping.
My monster stock is gear at around 7.08 That's 120/36. Start with that.
#3504
RandyB-Would you want to sell just afew things from your parts bin on your evo2 lot? I could use two C-hub front dogbones, a foam front shock tower and a solid top deck. Just thought i'd try!!! Check out our track pics on The Gate thread. Give you a place to run your evo this summer!!
#3505
Hello all
Here is Jilles Groskamp's car at the Reedy TC Race of Champions. Notice anything new?
#3506
Here is Jurai Hudy's Xray. Something new?
#3507
Originally posted by RCInfinity
Hello all
Hello all
On Jaraj's car, I the front A-arms look a little different.
-H
#3508
I noticed Jilles car is running the left side batteries to the front ala corally and the white pullies. Also for some weard reason the screws holding the screws holding the spur together seam unuasually spaced out. On Jurai's car it looks like a T1R with the solid top deck. I didn't notice anything out of the ordinary.
#3509
results at Reedy
Just wondering how the x-rays guys made out from the pics it looks like not any X-rays(could be wrong).Was there problems with the cars or just a bad weekend??I would of thought they would have been strong!
#3510
T1R On Carpet
I am very impressed with the handling and speed of my T1R/Evo2 hybrid. Car has the evo2 everything and a T1R chassis. It is so good right now!!! It also has the solid top deck and carpet front shock tower.
If your wondering if the T1R will be any good on carpet with foam tires-I would have to say its better than the evo2. I dont know why-but the car accelerates harder than the evo2!!! I dont get it!!
Ray
Ray
