Like Tree3Likes
Xray T1
Old 05-22-2003, 08:11 PM
  #3496
Trader Rating: 90 (100%+)
Default NEW PULLEY'S???
Since the pulley's are a different size what will the internal gear ratio change too??? Currently is 2.125
RBLove is offline
Old 05-22-2003, 09:17 PM
  #3497
Regional Moderator
BHenderson's Avatar
rob the last i heard it changed the internal to 1.77
BHenderson is offline
Old 05-23-2003, 05:57 AM
  #3498
RandyB's Avatar
oh no rob is back on the xray forum does this mean, could it be he has another!
RandyB is offline
Old 05-23-2003, 06:37 AM
  #3499
pucho's Avatar
I heard 1.88 closer t the Losi and Corally.
pucho is offline
Old 05-23-2003, 06:57 AM
  #3500
RandyB's Avatar
o.k. Decided that a rebuild was in order this week and I figured out a few cool things as you may know I have both cars. So I built a hybrid of the two.
I figured out that you can convert the top shaft of the evo 2 to a solid shaft removing the one way bearing and replacing it with the pullies from my T1R.
Guess I should have figured that out long ago. the Evo 2 top shaft has holes in it already to do so.
This makes me very happy as I have a ton of Trinity 64p spurs and could run them on the T1R top shaft cause of the mounting holes. problem solved
RandyB is offline
Old 05-23-2003, 06:59 AM
  #3501
RandyB's Avatar
how loose are you guys running the belts in stock? as loose as possible? or does that take them to the skipping point?
what are you guys gear a monster at 64 pitch 120t with rubber tires and tons of straight fast track high speed sweepers.
late
Randyb
RandyB is offline
Old 05-23-2003, 07:31 AM
  #3502
pucho's Avatar
On my T1R I run them as loose as posible and I have not had any problems with skiping.
My monster stock is gear at around 7.08 That's 120/36. Start with that.
pucho is offline
Old 05-23-2003, 08:07 AM
  #3503
RandyB's Avatar
thast about what I was figuring
RandyB is offline
Old 05-23-2003, 08:45 PM
  #3504
rayhuang's Avatar
RandyB-Would you want to sell just afew things from your parts bin on your evo2 lot? I could use two C-hub front dogbones, a foam front shock tower and a solid top deck. Just thought i'd try!!! Check out our track pics on The Gate thread. Give you a place to run your evo this summer!!
rayhuang is offline
Old 05-26-2003, 09:54 AM
  #3505
Neil Rabara's Avatar
Hello all
Here is Jilles Groskamp's car at the Reedy TC Race of Champions. Notice anything new?
Neil Rabara is offline
Old 05-26-2003, 09:58 AM
  #3506
Here is Jurai Hudy's Xray. Something new?
Old 05-26-2003, 10:16 AM
  #3507
Originally posted by RCInfinity
Hello all
On Jilles', I see the white prototype pulleys. Is that it?
On Jaraj's car, I the front A-arms look a little different.
-H
Headbanger is offline
Old 05-26-2003, 10:23 AM
  #3508
pucho's Avatar
I noticed Jilles car is running the left side batteries to the front ala corally and the white pullies. Also for some weard reason the screws holding the screws holding the spur together seam unuasually spaced out. On Jurai's car it looks like a T1R with the solid top deck. I didn't notice anything out of the ordinary.
pucho is offline
Old 05-26-2003, 04:20 PM
  #3509
TRL
Default results at Reedy
Just wondering how the x-rays guys made out from the pics it looks like not any X-rays(could be wrong).Was there problems with the cars or just a bad weekend??I would of thought they would have been strong!
TRL is offline
Old 05-27-2003, 06:18 AM
  #3510
rayhuang's Avatar
Default T1R On Carpet
I am very impressed with the handling and speed of my T1R/Evo2 hybrid. Car has the evo2 everything and a T1R chassis. It is so good right now!!! It also has the solid top deck and carpet front shock tower.
If your wondering if the T1R will be any good on carpet with foam tires-I would have to say its better than the evo2. I dont know why-but the car accelerates harder than the evo2!!! I dont get it!!
Ray
rayhuang is offline
