Xray T1
#2521
first thing you could do is take the car apart and get the chassis plate and use a clamp to compress the damaged area (maybe put some thin material inbetween the clamp and chassis for protection) and coat the wall with CA and let dry overnight. then check the chassis for tweak like Carbon F3 said.
#2524
Originally posted by RCCadet
RCInfinity :: Say Hi to Tony Phalen for me.
#2527
Originally posted by Pit-racer
I'll be going to Cali. around april, maybe we can meet at socal and race. Also I used to live there also And race at all the local tracks.I heard you were T.Q. at citrus college.
#2528
Those pesky AE guys! I won't be able to run expert like you do.Socal is one hard track to run...but like they say if you can run there you can run anywhere. The guys at snowbirds started to run the solid mid shaft and lighten front 1-way cause of the high traction, but change to the diffs.
#2529
i didn't clamp it. I just put CA. I Think it'll be alright. Checked for tweak on the Hudy and its fine. THanks
#2530
anybody know where to get the x-ray decal sheet
#2532
Originally posted by rc-zombies
I was able to get a 5sheet color set from Speedworld...unfortunately I got the last set. don't know when they will get more in.
#2533
Originally posted by RCInfinity
Next time I'll see him, I'll say you said hi. Whom should I say sends his regards?
