Xray T1
#2506
Great job to the Xray drivers at the Snowbirds!
#2507
Hey guys,
What do you think about the new Team Corally Assassin? Do you think its up to the XRAY Challenge?
http://www.hobbyx.com/reviews/assassin.htm
ENJOY..
ENJOY..
#2508
Any touring car is very capable of taking any win, or "Xray challenge". 90% of the car is the driver and his/her skills in driving and tuning to all the conditions.
#2509
The only thing that I can see that might be a problem with the assassin is the spur gear. It hangs out the back of the car past the rear shock tower. If you were to get hit in the rear, you could possibly damage the teeth on the spur gear. But other than that, it looks very nice.
#2511
Was at the bird's this week and picked up the new Xray brochure that includes the T1r. The kit looks really nice for entry level racer. What I want to know is why the two Xray drivers took each other out in the mod main ? I think it was Martin Hudy... and another Xray guy, just do not know who. Not sure... but if anyone can shed some light on this...
#2512
Originally posted by rc-zombies
Wasn't Yokomo testing a similar drive train?
and Aren't they coming out with a new car this year as well?
#2514
There is no noticeable difference between the solid shaft and the one way shaft on-power. There is a difference though when you are off-power going into a corner. The one-ways will allow you to corner better with no brake applied. With the solid shaft, you will feel the drag of the motor more, which allows you to dive into a corner deeper. I like the solid shaft because of that reason and also because there is less rotating mass causing the drive train to spool up a bit faster.
#2516
SoCal is my home track. I also visit many of the parking lot tracks in the area. When will you be down here again?
#2518
is my chassis okay
Heys guys i side swiped a wall. Here are some pics. Will my chassis be okay or do i need to get a new one????????
#2519
another pic
this is another pic
#2520
to check for a "rooted" chassis i normally pull apart my car, and put it on a flat surface (piece of 8mm think galss in my case) and see if it rocks back n forth..
just an idea
Rob Storey
just an idea
Rob Storey
